Learn how to seamlessly enroll users from Instagram Lead Ads into your Riggy account using Pabbly Connect. Follow our step-by-step tutorial for easy integration. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
Accessing Pabbly Connect for Instagram Lead Ads Integration
To start using Pabbly Connect for integrating Instagram Lead Ads, first, open your browser and visit the Pabbly Connect website. This platform allows you to automate tasks without any coding knowledge. Simply sign in to your account or create a new one if you’re a first-time user.
After logging in, you will see various Pabbly applications. Click on Pabbly Connect to access the dashboard where you can create your first workflow. This is the main hub for managing your integrations and automations.
In this section, we will create a workflow that connects Instagram Lead Ads to your Riggy account. Start by clicking on the “Create Workflow” button within Pabbly Connect. You will be prompted to name your workflow and choose a folder for organization.
For this example, name your workflow something like ‘Enroll Riggy User from Instagram Leads’. After naming it, click on the “Create” button. This action opens the workflow window where you can set up the trigger and action for your automation.
- Click on the trigger application and select Instagram Lead Ads.
- Choose the trigger event as ‘New Lead Instant’.
- Connect your Instagram account to Pabbly Connect.
Once you have set up the trigger, you will be ready to move on to the next step of mapping the data from your Instagram leads.
Mapping Data from Instagram Leads to Riggy
Now that you have set up your trigger in Pabbly Connect, it’s time to map the data from your Instagram leads to your Riggy account. This step is crucial to ensure that the information collected from your leads is accurately transferred.
After connecting Instagram Lead Ads, select your lead generation form and perform a test submission to capture the data. Once the lead is captured, you will see the details in Pabbly Connect. This allows you to map the fields from the lead to the corresponding fields in Riggy.
- Map the first name, last name, email, and phone number from the lead data.
- Ensure that the product hash is entered for the course you want to enroll the user into.
- Set the validity of access to the course, using -1 for lifetime access.
By mapping the data correctly, you ensure that each new lead is automatically enrolled in your Riggy account without any manual effort.
Finalizing the Integration with Pabbly Connect
With all the data mapped, it’s time to finalize your integration in Pabbly Connect. Click on the “Save and Send Test Request” button to check if everything is set up correctly. You should receive a positive response indicating that the lead has been successfully enrolled in your Riggy account.
After confirming the successful enrollment, visit your Riggy user management section to verify that the new user appears in the system. This step ensures that your automation is functioning as expected and that leads from Instagram are being captured effectively.
Check the user management section in Riggy to see the newly enrolled user. Ensure all lead details match what was submitted from Instagram Lead Ads.
This integration allows you to automate the enrollment process, saving time and ensuring that no leads are missed.
In this tutorial, we demonstrated how to use Pabbly Connect to integrate Instagram Lead Ads with Riggy for seamless user enrollment. By following the steps outlined, you can automate your lead management process effectively.
Utilizing Pabbly Connect not only streamlines the enrollment process but also enhances your ability to manage leads efficiently. Start automating your workflows today for better productivity and growth.
