Learn how to automate user enrollment in Thinkific using Paperform submissions with Pabbly Connect. Follow this detailed guide for seamless integration. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To start automating the enrollment of Thinkific users through Paperform submissions, you first need to access Pabbly Connect. This powerful automation tool allows you to connect various applications without any coding knowledge.
Visit the Pabbly website and sign in to your account. If you don’t have an account yet, you can sign up for free and enjoy a limited number of tasks each month. Once logged in, locate the Pabbly Connect option from the dashboard and click on ‘Access Now’ to begin.
After accessing Pabbly Connect, the next step is to create a new workflow that will automate the enrollment process. Click on the ‘Create Workflow’ button, and you will be prompted to name your workflow. A suitable name could be ‘Enroll Thinkific User on Paperform Submission’.
- Click on ‘Create’
- This opens the workflow window where you can set up triggers and actions.
In this workflow, the trigger will be a new submission in Paperform, while the action will be to enroll the user in Thinkific. This setup ensures that every time a user submits a form, they are automatically enrolled in the specified course.
3. Setting Up the Trigger with Paperform
To set the trigger, choose Pabbly Connect as the application and select ‘Paperform’ as the trigger event. You will receive a Webhook URL, which you need to copy. This URL will link your Paperform account to Pabbly Connect.
Log into your Paperform account, edit the form you wish to connect, and navigate to the ‘After Submission’ tab. Here, select ‘Integrations’ and then ‘Webhooks’. Paste the copied Webhook URL and select ‘New Submission’ as the trigger event. Click ‘Create’ to finalize the setup.
4. Testing the Integration with a Submission
With the trigger set up, it’s time to test the integration. Go back to your Paperform and fill out the registration form with a test submission. Once submitted, return to Pabbly Connect to check if the Webhook has captured the response.
- Ensure all details entered in the form are displayed correctly in the Pabbly Connect dashboard.
- This confirms that the connection between Paperform and Pabbly Connect is working.
Once the test submission is successful, you will see the captured data, confirming that Pabbly Connect is ready to process the enrollment automatically.
5. Enrolling the User in Thinkific
Now that the trigger is established, the next action is to enroll the user in Thinkific. Select ‘Thinkific’ as the action application in Pabbly Connect and choose ‘Create User’ as the action event. Connect your Thinkific account by providing the necessary subdomain.
Map the user details from the Paperform submission to the required fields in Thinkific, such as first name, last name, and email. After mapping, click ‘Save and Send’ to create the user. This action will automatically enroll the user into the specified course in Thinkific.
In conclusion, using Pabbly Connect to automate the enrollment of Thinkific users from Paperform submissions streamlines the process, saving time and reducing manual errors. This integration allows for a seamless experience for both you and your users, enhancing overall efficiency.
