Learn how to automate user enrollment from FlexiFunnels to Thinkific using Pabbly Connect. This detailed tutorial covers every step for seamless integration. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To start the integration process, first access Pabbly Connect by visiting its landing page. If you are a new user, click on the ‘Sign Up for Free’ button to create an account and explore the platform. Existing users should click on the ‘Sign In’ button to log into their accounts.
Once logged in, you will see various applications offered by Pabbly. Click on the ‘Access Now’ button for Pabbly Connect to reach the dashboard where you can create workflows for automation.
In Pabbly Connect, click on the blue button labeled ‘Create Workflow’ to begin. You will be prompted to name your workflow and select a folder to save it in. Name your workflow something descriptive, such as ‘How to Enroll Thinkific User on FlexiFunnels Purchase’ and save it in the ‘Automations’ folder.
- Select ‘FlexiFunnels’ as the trigger application.
- Choose ‘New Purchase’ as the trigger event.
After these steps, Pabbly Connect will provide you with a webhook URL, which you will use to connect FlexiFunnels with your workflow. Copy this URL for the next steps in the integration process.
3. Configuring FlexiFunnels with Pabbly Connect
Log into your FlexiFunnels account and navigate to the product you want to connect. Click on the ‘Edit’ option and go to the ‘Set Rules’ section. Here, you will add a new product rule for when a product is purchased.
- Select ‘Use Webhook’ and enter the webhook name as ‘New User’.
- Paste the webhook URL you copied from Pabbly Connect.
- Click ‘Save’ to finalize the connection.
After saving, Pabbly Connect will wait for a webhook response. To test this connection, proceed to make a test purchase in FlexiFunnels.
4. Enrolling the Thinkific User via Pabbly Connect
Once the test purchase is completed, return to Pabbly Connect and check for the captured response from FlexiFunnels. This response will include all the necessary details of the user who made the purchase.
Next, select Thinkific as your action application and choose ‘Create User’ as the action event. If prompted, connect your Thinkific account by entering your subdomain, which can be found in your Thinkific account URL.
Map the user details from the response received from FlexiFunnels. Leave the password field blank to allow users to set their own password.
Click on ‘Send Test Request’ to create the user in Thinkific. Upon successful creation, you will see a confirmation message in Pabbly Connect.
5. Finalizing User Enrollment in Thinkific
After successfully creating the user, you need to add another action step in Pabbly Connect to enroll the user in the course. Select Thinkific again and choose ‘Enroll User’ as the action event.
Connect to your existing Thinkific account and map the user ID from the previous step. Select the course to enroll the user, ensuring it remains static unless you want to change it dynamically.
Finally, click ‘Send Test Request’ to enroll the user in the specified course. After completing this step, check your Thinkific account to see the newly enrolled user in the course.
In this tutorial, we demonstrated how to use Pabbly Connect to automate the enrollment of Thinkific users upon purchase in FlexiFunnels. This setup enhances user experience by eliminating manual enrollment processes and allows for real-time updates.
