Learn how to integrate Razorpay and Learnyst using Pabbly Connect to automate student enrollment upon successful payments. Follow our step-by-step guide. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
1. Accessing Pabbly Connect for Razorpay Integration
To begin the integration process, first access Pabbly Connect by navigating to Pabbly.com/connect. This platform is essential for automating the enrollment of students in Learnyst upon successful Razorpay payments.
If you are a new user, click on ‘Sign Up for Free’ to create an account. Existing users can simply log in. After signing in, you will be directed to the applications page where you can select Pabbly Connect to set up your workflow.
Once in Pabbly Connect, click on ‘Create Workflow’ to initiate the process. You will be prompted to name your workflow. For this integration, name it ‘Enroll Student in Learnyst on Successful Razorpay Payment’ and click on ‘Create’.
  • Select Razorpay as your trigger application.
  • Choose ‘Payment Captured’ as the trigger event.
  • Copy the generated webhook URL for later use.
This setup ensures that every time a payment is captured through Razorpay, your workflow will be triggered automatically.
3. Setting Up Webhook in Razorpay
To connect Razorpay with Pabbly Connect, log into your Razorpay account and navigate to the settings. Here, locate the ‘Webhooks’ section and click on ‘Add New Webhook’.
Paste the copied webhook URL from Pabbly Connect into the URL field. Set the active event to ‘Payment Captured’ and click on ‘Create Webhook’. This step establishes a direct connection between Razorpay and Pabbly Connect.
4. Testing the Integration
After setting up the webhook, it’s crucial to test the integration. Go to the payment page in Razorpay and complete a test payment. Ensure all details are filled out accurately for a successful transaction.
  • Select the course you want to enroll in.
  • Fill in your personal details, including name and email.
  • Complete the payment process.
Once the payment is successful, return to Pabbly Connect to verify that the payment data has been captured correctly through the API response.
5. Enrolling Students in Learnyst
With the payment confirmed, the next step is to enroll the student in Learnyst. In Pabbly Connect, add an action step by selecting Learnyst as the action application. Choose the action event as ‘Sign Up’ to register the learner.
Connect your Learnyst account by providing the required School ID and API key, which can be found in the Learnyst dashboard under ‘Marketing’ and then ‘Integrations’.
After connecting, map the email address and course title from the previous steps to finalize the enrollment process. Click on ‘Save and Send Test Request’ to complete the integration. Check the Learners section in Learnyst to confirm that the student has been added successfully.
This tutorial illustrated how to use Pabbly Connect for integrating Razorpay with Learnyst, automating student enrollment upon successful payments. With this setup, you can efficiently manage course enrollments and enhance your educational platform.
