Learn how to automate student enrollment in Zenler through Razorpay payments using Pabbly Connect. Step-by-step guide for seamless integration. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To enroll paid students into Zenler via Razorpay, you must first access Pabbly Connect. Start by visiting the Pabbly website and signing into your account. If you don’t have an account, you can easily sign up for free and get 100 tasks monthly.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you will find options to create new workflows. Click on the ‘Create Workflow’ button to begin setting up the integration between Razorpay and Zenler.
In this step, you will create a new workflow specifically for enrolling students. Select the classic workflow builder and name it ‘Enroll Paid Students into Zenler via Razorpay’. Choose a folder for your workflow, like ‘Razorpay Automations’, and click on ‘Create’.
- Select the trigger application as Razorpay.
- Choose ‘Payment Captured’ as the trigger event.
- Set up the connection between Razorpay and Pabbly Connect.
After setting up the trigger, you will see two boxes: one for the trigger and one for the action. The trigger will initiate the workflow whenever a payment is captured in Razorpay.
3. Setting Up the Webhook in Razorpay
To connect Razorpay with Pabbly Connect, you need to set up a webhook. In your Razorpay dashboard, click on ‘Developers’ and then ‘Webhooks’. Click on ‘Add New Webhook’, where you will enter the webhook URL provided by Pabbly Connect.
- Paste the webhook URL from Pabbly Connect.
- Set the active event to ‘Payment Captured’.
- Click on ‘Create Webhook’ to save your settings.
Once the webhook is created, return to Pabbly Connect and wait for the webhook response. This indicates that the connection is successfully established.
4. Enrolling Students in Zenler
After receiving a successful payment response, the next step is to enroll students in Zenler. In Pabbly Connect, select Zenler as the action application and choose ‘Enroll User to a Course’ as the action event.
Connect Zenler by entering the API key and school account details. Map the course ID to the relevant course in Zenler. Use mapping to dynamically insert the student’s details from Razorpay.
This mapping ensures that each new payment automatically enrolls the correct student in the specified course, maintaining the workflow’s efficiency.
5. Testing and Finalizing the Integration
Once all configurations are done, it’s time to test the workflow. Trigger a test payment in Razorpay to see if the student enrollment occurs in Zenler as expected. Monitor the Pabbly Connect dashboard for the webhook response.
If successful, you will see the new user enrolled in the Zenler account. This confirms that the integration is working perfectly, automating the process of enrolling students after payment confirmation.
In this tutorial, we demonstrated how to enroll paid students into Zenler via Razorpay using Pabbly Connect. This integration automates the enrollment process, saving time and effort while ensuring accuracy. Utilize Pabbly Connect to enhance your workflow efficiency and streamline your business operations.
