Learn how to create Sendy subscribers from webhook responses using Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To create Sendy subscribers from webhook responses, first access Pabbly Connect. Open your browser and navigate to Pabbly.com/connect. If you are a new user, click on the ‘Sign up for free’ button to create an account. Existing users can click the ‘Sign in’ button to log in.
Once logged in, you will be directed to the all-app section of Pabbly. Here, you will find all Pabbly products. Click on ‘Access Now’ under Pabbly Connect to reach the dashboard, where you can manage your workflows.
In the Pabbly Connect dashboard, click on the ‘Create Workflow’ button located at the top right corner. A dialog box will prompt you to name your workflow. Enter a name such as ‘Create Sendy Subscriber from Webhook Response’ and click ‘Create’. using Pabbly Connect
- Choose Webhook by Pabbly as the trigger application.
 - Configure it to capture responses from your chosen form application.
After setting up the trigger, you will see two windows: one for the trigger and one for the action. This setup allows you to specify what happens when a new webhook response is captured. Select Webhook as your trigger.
3. Configuring Webhook Integration with JotForm
To capture responses, you need to connect your form application to Pabbly Connect. For this tutorial, we will use JotForm. Copy the webhook URL provided by Pabbly Connect and navigate to your JotForm account.
In JotForm, go to the settings of your desired form, select Integrations, and find Webhooks. Paste the copied webhook URL and complete the integration. Now, whenever the form is filled out, the response will be captured by Pabbly Connect.
4. Creating a New Subscriber in Sendy
After capturing the webhook response, the next step is to create a new subscriber in Sendy. In Pabbly Connect, select Sendy as your action application. Choose the ‘Add Subscriber’ action event and click on ‘Connect’ to establish a connection. using Pabbly Connect
When prompted, enter your Sendy API key and sending URL. You can find these details in your Sendy account under the settings. Make sure to copy the API key and the domain URL accurately without any trailing slashes.
- Map the list ID where the new subscriber will be added.
 - Fill in the subscriber’s details using the mapped data from the webhook response.
Once you have entered all necessary details, click on ‘Save and Send Test Request’ to verify that the subscriber has been created successfully.
5. Verifying the Subscriber Creation in Sendy
After executing the test request, check your Sendy account to confirm that the new subscriber has been added. Navigate to the list you specified and look for the subscriber created from the webhook response. using Pabbly Connect
If the subscriber appears with the correct details, your workflow is successful! You have successfully integrated Pabbly Connect with Sendy to automate the process of subscriber creation from webhook responses.
In this tutorial, we explored how to create Sendy subscribers from webhook responses using Pabbly Connect. This automation simplifies the process and saves time by ensuring that every response from your form leads to a new subscriber being added to your Sendy account.
