Learn how to automate the creation of Sendy subscribers from Shopify orders using Pabbly Connect. Step-by-step tutorial with detailed instructions. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
1. Accessing Pabbly Connect for Shopify and Sendy Integration
To start automating your Shopify orders with Pabbly Connect, first, access the platform. Visit the Pabbly Connect website and sign in or create a new account. If you’re new, click on the ‘Sign Up for Free’ button to quickly create your account and receive 100 free tasks to explore.
Once logged in, navigate to the dashboard where you can find all the applications offered by Pabbly. Click on the Pabbly Connect icon to begin setting up your integration workflow.
To create a workflow, click on the ‘Create Workflow’ button located in the top right corner of your Pabbly Connect dashboard. You will be prompted to name your workflow. For this tutorial, name it ‘Create Sendy Subscriber for Shopify Orders’. This name reflects the purpose of the workflow. using Pabbly Connect
After naming your workflow, you will see two sections: Trigger and Action. In this case, select Shopify as your trigger application and choose ‘New Order’ as the trigger event. This setup ensures that every time a new order is placed in Shopify, the workflow initiates.
- Select Shopify as the trigger application.
- Choose ‘New Order’ as the trigger event.
Click ‘Create’ to finalize your workflow setup. Now, you will be provided with a Webhook URL from Pabbly Connect to connect your Shopify account.
3. Setting Up the Webhook in Shopify
Next, you need to set up the Webhook in your Shopify account. Go to your Shopify store, click on ‘Settings’, and then select ‘Notifications’. Scroll down to find the Webhooks section and click on ‘Create Webhook’. Here, select the event type as ‘Order Creation’ to ensure that the Webhook captures new orders.
Paste the Webhook URL you copied from Pabbly Connect into the appropriate field. Make sure to select JSON as the format and save the Webhook. This connection allows Shopify to send order details to Pabbly Connect whenever a new order is placed.
4. Testing the Integration with a Dummy Order
After setting up the Webhook, it’s time to test the integration. Go back to your Shopify store and place a dummy order for a product. Fill in the required details like customer email, name, and address. Once the order is placed, return to Pabbly Connect to see if it captures the response.
Upon successful order placement, Pabbly Connect will show the order details received from Shopify. This includes the product name, customer name, and email. This step is crucial as it confirms that the integration is working correctly and ready for the next phase.
5. Creating a New Subscriber in Sendy
Now that you have confirmed the integration is working, it’s time to create a new subscriber in Sendy. In the Action section of your workflow, select Sendy as the action application and choose the ‘Add Subscriber’ action event. Click on connect and enter your Sendy URL and API key to establish the connection. using Pabbly Connect
Next, map the details received from Shopify to the Sendy fields. Enter the List ID, customer name, and email from the Shopify order response. This mapping ensures that every new order placed in Shopify leads to an automatic subscriber creation in Sendy with the correct details.
- Enter the List ID from your Sendy account.
- Map customer name and email from the Shopify response.
Click ‘Save and Send Test Request’ to finalize the process. If successful, you will see a confirmation message in Pabbly Connect, and you can check your Sendy account to verify that the new subscriber has been added.
This tutorial demonstrated how to create Sendy subscribers automatically from new Shopify orders using Pabbly Connect. By following the steps outlined, you can streamline your order processing and enhance your email marketing efforts effectively. Automating this process saves time and ensures that your subscriber list is always up-to-date with new customers.
