Learn how to create Salesforce leads from MagicBricks inquiries using Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To create Salesforce leads from MagicBricks inquiries, the first step is to access Pabbly Connect. Open a new tab and type Pabbly.com/connect in your browser to reach the landing page.
On the landing page, you have two options: sign in or sign up for free. If you are a new user, click on ‘sign up for free’ to get 100 tasks free every month. Existing users should click on ‘sign in’ to access their accounts. Once logged in, navigate to the applications and select Pabbly Connect.
Once you are in Pabbly Connect, click on the ‘create workflow’ button. You will then be prompted to select between the new or classic workflow builder. Choose the new workflow builder for a modern interface.
- Enter the workflow name: ‘Create Salesforce leads from MagicBricks inquiries’.
- Select the folder as ‘Automations’.
- Click on the ‘create’ button.
After clicking create, you will enter the workflow window where you can set up triggers and actions. This is crucial for the automation process using Pabbly Connect.
3. Setting Up the Trigger with MagicBricks
In the workflow window, click on the ‘add trigger’ button. Search for MagicBricks and select it as the trigger application. Choose the event ‘New Leads’ and click on ‘Connect’.
You will receive a webhook URL. This URL needs to be provided to your MagicBricks account manager because MagicBricks does not allow users to input webhooks directly. Once they add this URL, leads will automatically be sent to Pabbly Connect as web responses.
4. Capturing Lead Details and Creating Salesforce Lead
After setting up the webhook, you will capture the lead details like first name, last name, phone number, email address, and city. This information will be used to create a lead in Salesforce.
Next, click on ‘add new action step’ and search for Salesforce. Select it and choose the event ‘Create Lead’. Click on ‘Connect’. If you have an existing connection, select it. Otherwise, create a new connection by logging into your Salesforce account through Pabbly Connect.
- Map the lead details from MagicBricks to Salesforce fields.
- Click on ‘Save and Send Test Request’ to create the lead.
Once the test request is successful, you will see that a new lead has been created in Salesforce, confirming the seamless integration facilitated by Pabbly Connect.
5. Conclusion: Automate Your Lead Generation with Pabbly Connect
By following these steps, you can effectively create Salesforce leads from MagicBricks inquiries using Pabbly Connect. This automation allows your sales team to follow up quickly and efficiently on new leads.
Try this automation for your own business and experience the efficiency of Pabbly Connect. If you have any questions, feel free to reach out for support or join the community for assistance.
In this tutorial, we explored how to create Salesforce leads from MagicBricks inquiries using Pabbly Connect. By automating this process, you can enhance your lead management and improve your business operations.
