Learn how to automate posting from Tumblr to Pinterest using Pabbly Connect. This step-by-step guide covers everything you need to know! Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
1. Setting Up Pabbly Connect for Tumblr and Pinterest Integration
To start using Pabbly Connect, first, you need to log into your account. If you don’t have an account, you can sign up for a free trial that offers 100 automation tasks each month. This allows you to create workflows that connect different applications like Tumblr and Pinterest seamlessly.
Once logged in, you will be directed to the dashboard. Here, you can create a new workflow by clicking on the ‘Create Workflow’ button. Name your workflow something like ‘Tumblr to Pinterest Automation’ and click on ‘Create’ to proceed. This is where the magic of Pabbly Connect begins, allowing you to set up triggers and actions.
2. Selecting Tumblr as the Trigger Application
In this section, you will set up Tumblr as the trigger application in Pabbly Connect. Select Tumblr from the list of applications and choose the trigger event as ‘New Post in Dashboard’. This event will initiate the workflow whenever you create a new post on Tumblr.
- Choose Tumblr as your trigger application.
- Select the event ‘New Post in Dashboard’.
- Click on ‘Connect’ and authorize Pabbly Connect to access your Tumblr account.
Once you have connected your Tumblr account, click on ‘Save and Send Test Request’ to fetch the latest post data. This step is crucial as it allows Pabbly Connect to pull in the necessary information that will be used in the next steps.
3. Formatting the Image URL with Text Parser
After fetching your Tumblr post data, the next step is to format the image URL properly using the Text Formatter feature in Pabbly Connect. This is essential because the fetched data may include HTML tags that need to be removed to get a clean image link.
- Search for ‘Text Formatter’ and select ‘Text Parser’ as the action event.
- Map the image link from the previous step.
- Set the ‘Text Match Before’ and ‘Text Match After’ parameters to extract the correct image URL.
Once you have configured the Text Parser, click on ‘Save and Send Test Request’ to ensure you receive the correct image URL. This formatted URL will be crucial for creating your Pinterest pin.
4. Creating a Pin on Pinterest Using Pabbly Connect
Now that you have the formatted image URL, the next step is to create a pin on Pinterest. In Pabbly Connect, add a new action step and select Pinterest as the application. Choose the action event ‘Create Pin’ to proceed with the pin creation process.
Connect your Pinterest account by allowing access. Select the board where you want to create the pin. Map the title, description, and the image URL obtained from the previous steps.
After filling in the required details, click on ‘Save and Send Test Request’. This will create a new pin on your selected Pinterest board, showcasing the content from your Tumblr post. You can verify this by checking your Pinterest board for the new pin.
5. Recap and Benefits of Using Pabbly Connect for Automation
In summary, you have successfully set up an automation workflow using Pabbly Connect to connect Tumblr and Pinterest. This integration allows you to automatically create pins on Pinterest whenever you publish a new post on Tumblr, saving you time and effort.
By utilizing Pabbly Connect, you streamline your social media management and ensure your content reaches a broader audience without manual intervention. This automation is not only efficient but also enhances your online presence effortlessly.
Using Pabbly Connect, you can easily automate the process of posting from Tumblr to Pinterest. This integration enhances productivity and ensures that your audience receives updates in real-time. Start using Pabbly Connect today to simplify your social media management!
