Learn how to automate the creation of Omnisend subscribers from webhook responses using Pabbly Connect and Pabbly Connect in this detailed tutorial. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To create an Omnisend subscriber from a webhook response, you need to access Pabbly Connect. This platform will automate the process, allowing you to send data seamlessly from various applications to Omnisend.
First, sign up for a free account on Pabbly Connect. Once logged in, navigate to the dashboard where you can start creating a workflow. Click on the ‘Create Workflow’ button and name it, for example, ‘Webhooks to Omnisend’. Select the appropriate folder and click ‘Create’ to proceed.
2. Configuring the Webhook Trigger in Pabbly Connect
In this step, you will set up the trigger that captures webhook responses. Select ‘Webhook’ from the trigger options in your Pabbly Connect workflow. Then, choose ‘Catch Hook’ as the trigger event.
- Add this URL to the application sending the data.
- In this tutorial, we are using Pabbly Form Builder for demonstration.
Once you have added the webhook URL to your application, Pabbly Connect will wait to capture the response. This means that every time there’s a form submission in Pabbly Form Builder, the data will be sent to the webhook URL.
3. Capturing Form Submission Data
After setting up the webhook, the next step is to capture the form submission data. Make a test submission in your Pabbly Form Builder to generate a webhook response. This will allow Pabbly Connect to receive the data.
For example, enter a name, email address, and other details in the form. Once submitted, Pabbly Connect will show that it has received the data in the trigger step. You will see all the form responses displayed, confirming that the webhook setup is working correctly.
4. Sending Data to Omnisend to Create a Subscriber
Now that you have captured the webhook response, it’s time to send this data to Omnisend. In the action step of your Pabbly Connect workflow, search for and select Omnisend. Choose the action event as ‘Create Subscriber’.
- Connect your Omnisend account by entering the API key.
- Select the identifier type (email or phone number) for the subscriber.
- Map the fields from the webhook response to the corresponding fields in Omnisend.
Once all details are mapped correctly, click ‘Save and Send Test Request’. If successful, you will see a confirmation that the subscriber has been created in Omnisend.
5. Verifying Subscriber Creation in Omnisend
The final step is to verify that the new subscriber has been created in your Omnisend account. Navigate to the audience section in Omnisend and check for the subscriber details you just sent.
Upon refreshing the audience page, you should see the newly added subscriber with all the information that was captured from the webhook response. This confirms that the automation workflow using Pabbly Connect is functioning as intended.
This tutorial has guided you through the process of creating an Omnisend subscriber from a webhook response using Pabbly Connect and Pabbly Form Builder. By following these steps, you can automate subscriber creation efficiently, saving time and ensuring accurate data transfer.
