Learn how to automate Mailgun member creation from Typeform submissions using Pabbly Connect with this step-by-step guide. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To start automating the creation of Mailgun members from Typeform submissions, you need to access Pabbly Connect. Begin by visiting the Pabbly Connect homepage by typing the URL in your browser.
Once on the homepage, you will see options to either sign in or sign up. If you are a new user, click on the ‘Sign Up for Free’ button to create an account, which will provide you with 100 free tasks every month to explore the platform.
After signing in to Pabbly Connect, navigate to the dashboard where you can manage your workflows. Click on the ‘Create Workflow’ button to begin setting up your automation.
- Name your workflow, for example, ‘Create Mailgun Member on Typeform Submission.’
- Select the appropriate folder for your workflow.
- Click on the ‘Create’ button to finalize your workflow setup.
After creating the workflow, you will see two main sections: Trigger and Action. The Trigger is where you define what event starts the workflow, while the Action specifies what happens when that event occurs.
3. Integrating Typeform as the Trigger Application
In this step, you will set Typeform as the trigger application in your Pabbly Connect workflow. Select Typeform from the list of applications.
Next, choose the trigger event as ‘New Entry’. This means that every time a new form submission is made in Typeform, it will trigger the workflow. To connect Typeform with Pabbly Connect, click on the ‘Connect’ button and select ‘Add New Connection’.
- You will need to log in to your Typeform account to authorize the connection.
- Select the specific form you want to connect, such as your ‘Inquiry Form.’
Once you have selected the form, click on ‘Save and Send Test Request.’ This will allow Pabbly Connect to capture the response from the Typeform submission, confirming that the connection is successful.
4. Integrating Mailgun as the Action Application
Now that Typeform is set as the trigger, it’s time to integrate Mailgun as the action application in Pabbly Connect. Select Mailgun from the list of applications and choose the action event as ‘Create Mailing List Member.’
To establish the connection, click on ‘Connect’ and then ‘Add New Connection.’ You will need to enter your Mailgun API details including:
API Key Mailgun Domain Mailgun Host
After entering these details, click on ‘Save’ to create the connection. This allows Pabbly Connect to automatically add new leads from Typeform submissions to your Mailgun mailing list.
5. Finalizing Your Integration and Testing
With both Typeform and Mailgun connected through Pabbly Connect, it’s time to finalize the integration. You will need to specify the list in Mailgun where new members will be added. Ensure the list is created in Mailgun before mapping it in Pabbly Connect.
Map the fields from Typeform to Mailgun, ensuring that the email address and name fields are correctly matched. Click on ‘Save and Send Test Request’ to test the integration. If successful, you will see the new member added to your Mailgun list.
To ensure everything works correctly, submit another form through Typeform and check Mailgun to see if the new lead is added automatically. This confirms that your automation is functioning as intended, allowing you to manage leads effortlessly through Pabbly Connect.
In this tutorial, we explored how to automate the creation of Mailgun members from Typeform submissions using Pabbly Connect. By following these steps, you can streamline your lead management process and enhance your marketing efforts efficiently.
