Learn how to automate your Instagram Lead Ads to Mailgun integration using Pabbly Connect with this step-by-step tutorial. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
1. Accessing Pabbly Connect for Instagram Lead Ads
To create a Mailgun member for Instagram Lead Ads, you’ll first need to access Pabbly Connect. This platform is essential for automating the integration between your Instagram Lead Ads and Mailgun.
Start by visiting the Pabbly Connect homepage. If you are a new user, click on ‘Sign Up Free’ to create an account and get 100 free tasks every month. Existing users should click on ‘Sign In’ to access their dashboard.
Once logged into Pabbly Connect, you will need to create a new workflow. Click on the ‘Create Workflow’ button located at the top right corner of your dashboard.
- Name your workflow, e.g., ‘Create Mailgun Member for Instagram Lead’.
- Select a folder to organize your workflows.
- Click on the ‘Create’ button to finalize your workflow setup.
With your workflow created, you can now define the trigger and action. The trigger will be set to Instagram Lead Ads, allowing Pabbly Connect to capture new leads automatically.
3. Setting Up the Instagram Lead Ads Trigger
In this step, you will configure the trigger for Instagram Lead Ads within Pabbly Connect. Select Instagram Lead Ads as your trigger application.
- Choose the trigger event as ‘New Lead Instant’.
- Connect your Instagram account by clicking on ‘Connect’.
- Select your Facebook page linked to your Instagram account.
After selecting the appropriate page, choose the lead generation form you want to capture leads from. Click on ‘Save and Send Test Request’ to ensure everything is connected properly. This step is crucial for Pabbly Connect to receive leads from your Instagram ads.
4. Connecting Mailgun in Pabbly Connect
Now that you have set up the trigger, it’s time to connect your Mailgun account to Pabbly Connect. In the action step, select Mailgun as your action application.
Choose the action event as ‘Test New Mailing List Member’. Connect your Mailgun account by entering your API Key, Mailgun host, and domain name. Select the mailing list where new leads should be added.
Once connected, map the fields from the Instagram lead to the Mailgun member fields. This ensures that every new lead captured by Pabbly Connect is automatically added to your mailing list in Mailgun.
After setting up the integration, it’s essential to test it. Generate a test lead using the lead testing tool provided by Meta. This will simulate a lead submission through your Instagram Lead Ads.
Once the test lead is submitted, check your Mailgun account to verify that the new member has been added to the mailing list. Pabbly Connect should capture the lead details, and you will see the new entry in your Mailgun mailing list. This confirms that the integration is working correctly.
In this tutorial, we explored how to create a Mailgun member for Instagram Lead Ads using Pabbly Connect. By automating this process, you ensure timely follow-ups with potential clients, enhancing your business efficiency.
