Learn how to create a MailerLite subscriber for specific product payments in Stripe using Pabbly Connect. Step-by-step tutorial for seamless integration. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To create a MailerLite subscriber for specific product payments in Stripe, we will use Pabbly Connect. Start by navigating to the Pabbly Connect website at pa.com/c/connect. Here, you will find options to sign in or sign up for free.
If you are an existing user, click on the ‘Sign In’ button. If you are new, the sign-up process is quick and straightforward, taking less than two minutes. Once signed in, you will arrive at the applications page where you can access Pabbly Connect.
After accessing Pabbly Connect, click on the ‘Create Workflow’ button located on the dashboard. A dialog box will appear, prompting you to name your workflow. Enter a name like ‘Create MailerLite Subscriber for Specific Product Payment in Stripe’ and click on ‘Create’ to proceed.
- Click on ‘Create Workflow’.
Upon creating the workflow, you will see options for setting up triggers and actions. For this integration, the trigger application will be Stripe, and the action application will be MailerLite. This setup will allow you to automate the process of creating subscribers in MailerLite whenever a payment is completed in Stripe.
In this step, we will configure the trigger in Pabbly Connect. Select Stripe as your trigger application, and then choose the ‘Checkout Completed’ event from the list of trigger events. This event will initiate the workflow when a payment is completed.
After selecting the trigger event, Pabbly Connect will provide you with a webhook URL. Copy this URL, as it will be used to set up the webhook in your Stripe account. This is essential for capturing payment data for specific products.
4. Configuring the Webhook in Stripe
Now, navigate to your Stripe dashboard and go to the ‘Developers’ section. Click on ‘Webhooks’ and then select ‘Add Endpoint’. Here, paste the webhook URL you copied from Pabbly Connect. You can add a description if you wish.
- Paste the copied webhook URL.
- Select the latest API version.
- Choose the event ‘Checkout Session Completed’.
Once you have configured the webhook, test the connection by making a payment for a specific product in Stripe. This will send a test response back to Pabbly Connect, allowing you to verify that the integration is functioning correctly.
5. Creating a Subscriber in MailerLite
After successfully receiving the test response in Pabbly Connect, we will now set up the action to create a subscriber in MailerLite. Select MailerLite as your action application and choose the ‘Create or Update Subscriber’ action event.
To connect Pabbly Connect with MailerLite, you will need an API token. Generate this token in your MailerLite account and paste it into Pabbly Connect. Once connected, map the subscriber’s email and other details from the Stripe payment data to create a new subscriber.
This tutorial has detailed how to create a MailerLite subscriber for specific product payments in Stripe using Pabbly Connect. By following the steps outlined, you can automate your subscriber management effectively. This integration ensures that every payment made for a specific product results in a new subscriber being created in MailerLite, streamlining your workflow.
