Learn how to automate the creation of Mailercloud contacts from ThriveCart purchases using Pabbly Connect. Follow this step-by-step guide for seamless integration. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To create a Mailercloud contact from a ThriveCart purchase, start by accessing Pabbly Connect. As an existing user, sign in to your account. If you are new, click on the ‘Sign Up for Free’ button to create your account, which allows you 100 tasks per month at no cost.
Once signed in, navigate to the dashboard by clicking on ‘Access Now’. From here, you can create a new workflow by clicking on the ‘Create Workflow’ button. Name your workflow as ‘Create Mailercloud Contact from ThriveCart Purchase’ and save it in a folder named ‘ThriveCart to Mailercloud’ to keep your integrations organized.
2. Setting Up Trigger and Action in Pabbly Connect
In this step, you will set up the trigger and action for your workflow in Pabbly Connect. The trigger application will be ThriveCart, and the trigger event will be ‘Product Purchase’. This means that every time a product is purchased, the workflow will initiate.
- Select ThriveCart as the trigger application.
- Choose ‘Product Purchase’ as the trigger event.
- Click on ‘Connect’ to establish a connection between ThriveCart and Pabbly Connect.
Next, you will need to connect Pabbly Connect to your ThriveCart account. Copy the API key from your ThriveCart settings under API and Webhooks. Paste this key into Pabbly Connect and click ‘Save’. This establishes a successful connection, enabling Pabbly Connect to capture purchase data from ThriveCart.
3. Selecting Product and Testing the Connection
After establishing the connection, you need to select the product for which you want to set up the automation in Pabbly Connect. Choose the product from the dropdown menu, ensuring that it is set to ‘Test Mode’ for testing purposes.
- Select the product name from the dropdown.
- Ensure the product status is set to Test Mode.
- Click on ‘Save and Send Test Request’ to capture purchase data.
Once you click ‘Save and Send Test Request’, Pabbly Connect will wait for a webhook response. To generate this response, proceed to make a test purchase on ThriveCart. Fill out the necessary details like name, email, and payment information, and complete the order. Once the order is confirmed, you will see a positive response in Pabbly Connect indicating that the details were captured successfully.
4. Creating a Contact in Mailercloud
With the purchase data captured, the next step is to create a contact in Mailercloud using Pabbly Connect. First, you will need to set up a connection between Mailercloud and Pabbly Connect. Click on ‘Connect’ and paste your Mailercloud API key, which you can generate from your Mailercloud account under API Integrations.
Navigate to Mailercloud account settings and generate a new API key. Copy the API key and paste it into Pabbly Connect. Click ‘Save’ to establish the connection.
After the connection is established, select the list in Mailercloud where you want to add the contact. Choose the list named ‘ThriveCart Customers’. Next, you will map the fields from the ThriveCart purchase data to the corresponding fields in Mailercloud, such as email, first name, last name, phone number, and address details. This mapping ensures that the correct data is sent each time a purchase is made.
After mapping the fields, click on ‘Send Test Request’ in Pabbly Connect. This action will send the mapped data to Mailercloud and create a new contact based on the test purchase. You should receive a confirmation response indicating that the contact was created successfully.
To verify, go to your Mailercloud account, refresh the ‘ThriveCart Customers’ list, and you should see the new contact listed there. This confirms that the integration is working as intended. Now, every time a customer makes a purchase on ThriveCart, their details will automatically be added to your Mailercloud contact list.
In this tutorial, we demonstrated how to create a Mailercloud contact from a ThriveCart purchase using Pabbly Connect. This integration streamlines your workflow by automating contact creation, saving you time and ensuring your email list is always up to date.
