Learn how to create Kit subscribers from LinkedIn Lead Gen Forms leads using Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To create Kit subscribers from LinkedIn Lead Gen Forms leads, we will use Pabbly Connect. Begin by opening your web browser and searching for Pabbly Connect. This platform allows seamless integration between LinkedIn and Kit.
Once on the Pabbly Connect landing page, you’ll find options to sign in or sign up. If you are a new user, click on the ‘Sign up for free’ button to create an account. Existing users can simply log in to access their dashboard.
After logging into Pabbly Connect, click on the ‘Create Workflow’ button. You will see a prompt to name your workflow; name it according to your objective, such as ‘Create Kit Subscriber from LinkedIn Leads’.
- Select the folder for your workflow.
- Click ‘Create’ to proceed.
This will take you to the main workflow setup window, where you will define your trigger and action. The trigger is the first event that initiates the workflow, while the action is what happens as a result.
3. Setting Up the Trigger with LinkedIn Lead Gen Forms
In this step, we will set up the trigger in Pabbly Connect. Search for ‘LinkedIn Lead Gen Forms’ as your trigger application. Select it, then choose the trigger event as ‘New Lead Gen Form Response’.
Next, connect LinkedIn Lead Gen Forms with Pabbly Connect by clicking on ‘Connect’. Choose ‘Add New Connection’ and follow the prompts to link your LinkedIn account. Once connected, select the specific ad account and the lead form you will be using to capture new leads.
4. Generating Leads and Receiving Responses in Pabbly Connect
Now that your trigger is set, generate a test lead from your LinkedIn Lead Gen Forms. Fill in the required fields in your lead form and submit it. This action will send the lead details to Pabbly Connect.
- Access your LinkedIn Lead Ads account.
- Submit the lead form with test details.
- Return to Pabbly Connect and click ‘Send Test’.
Within a few minutes, you will receive the response containing the new lead’s details, confirming that the integration is successfully capturing leads from LinkedIn.
5. Creating a Subscriber in Kit Using Pabbly Connect
With the lead details received, it’s time to create a subscriber in Kit using Pabbly Connect. Set up the action by searching for ‘Kit’ as your action application. Choose ‘Add Subscriber to a Sequence’ as your action event.
Connect Kit to Pabbly Connect by providing your API key and secret from your Kit account. After successfully connecting, select the sequence where you want to add the new subscriber. Map the lead details from the LinkedIn response to the corresponding fields in Kit.
In this tutorial, we explored how to create Kit subscribers from LinkedIn Lead Gen Forms leads using Pabbly Connect. By following these steps, you can automate the process of adding new leads to your email list, ensuring efficient follow-ups and improved lead management without any coding skills.
