Learn how to automatically create Kit subscribers from FlexiFunnels purchases using Pabbly Connect. Follow this detailed tutorial for seamless integration. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To create a Kit subscriber when a purchase is made on FlexiFunnels, you first need to access Pabbly Connect. Start by navigating to the Pabbly Connect homepage by entering the URL in your browser.
Once there, you will see options to sign in or sign up. If you are a new user, click on ‘Sign Up Free’ to create an account and get 100 free tasks monthly. If you are an existing user, simply sign in. After logging in, you will reach the dashboard where you can create your workflow.
In this step, you will create a workflow that connects FlexiFunnels and Kit through Pabbly Connect. Click on the ‘Create Workflow’ button located at the top right corner of the dashboard.
  • Name your workflow as ‘Create Kit Subscriber on FlexiFunnels Purchase’.
  • Select a folder for your workflow, such as ‘Automations’.
  • Click the ‘Create’ button to finalize your workflow setup.
Now, you will see the workflow interface where you can set up your trigger and action. This is where the automation process begins, allowing you to create a seamless connection between FlexiFunnels and Kit using Pabbly Connect.
3. Setting Up the Trigger with FlexiFunnels
To automate the process, select FlexiFunnels as your trigger application in Pabbly Connect. Choose the trigger event as ‘New Purchase’. This means every time a purchase is made, the workflow will be triggered automatically.
After selecting the trigger event, you will receive a webhook URL. Copy this URL and head over to your FlexiFunnels account. In FlexiFunnels, navigate to the product settings of the item you are selling, and set up a webhook using the URL you copied.
  • Go to ‘Product’ settings and click on ‘Set Rules’.
  • Choose ‘Product is purchased’ for the conditions.
  • Paste the webhook URL and save the settings.
This setup ensures that whenever a purchase is made, Pabbly Connect will capture the response, allowing you to proceed with the next steps in your integration.
4. Setting Up the Action with Kit
After configuring the trigger, it’s time to set up the action in Pabbly Connect. Select Kit as your action application and choose ‘Add Subscriber to a Form’ as your action event. This means that every new purchase will automatically add the buyer as a subscriber in your Kit account.
To connect Kit with Pabbly Connect, you will need to enter your API key and secret from your Kit account. Navigate to your Kit account settings, find the API section, and copy the required keys.
Paste the API key and secret into the corresponding fields in Pabbly Connect. Select the form where subscribers will be added. Map the fields such as first name, last name, email, and phone number from the trigger response.
Once you have mapped all the required fields, send a test request through Pabbly Connect to ensure everything is set up correctly. This finalizes your integration, allowing automatic subscriber creation in Kit whenever a purchase is made on FlexiFunnels.
5. Testing the Integration
Now that your workflow is set up, it’s essential to test the integration to ensure it works as expected. Make a test purchase on your FlexiFunnels payment page using dummy data.
After completing the purchase, go back to your Kit account and refresh the subscribers’ list. You should see the new subscriber added automatically. This confirms that Pabbly Connect is functioning correctly and your automation is complete.
In summary, you have successfully set up an integration that automatically adds new purchasers from FlexiFunnels as subscribers in Kit using Pabbly Connect. This automation saves time and enhances customer engagement by keeping your buyers informed.
In this tutorial, we explored how to create Kit subscribers automatically when purchases are made on FlexiFunnels using Pabbly Connect. This integration streamlines your workflow and enhances customer engagement, making it an essential tool for online sellers.
