Learn how to automate creating Kit subscribers from Cashfree payments using Pabbly Connect in this detailed step-by-step tutorial. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To create a Kit subscriber on Cashfree Payment, we will utilize Pabbly Connect. First, navigate to Pabbly Connect by typing ‘Pabbly.com/connect/’ in your browser. This platform enables seamless automation between applications without any coding knowledge.
After accessing the site, sign in to your existing account or create a new one. Upon signing in, you will be directed to the Pabbly Connect dashboard where you can manage your workflows and integrations effectively.
To automate the process of creating a Kit subscriber, we need to establish a new workflow in Pabbly Connect. Click on the ‘Create Workflow’ button and provide a name such as ‘Create Kit Subscriber on Cashfree Payment’. Select the appropriate folder for better organization.
- Name your workflow.
- Select a folder for organization.
- Click ‘Create’ to proceed.
Once the workflow is created, you will see two boxes labeled Trigger and Action. The trigger will be set to Cashfree, indicating that whenever a payment occurs, a subscriber will be created in Kit.
3. Setting Up Cashfree as Trigger in Pabbly Connect
In this step, we will configure Cashfree as the trigger application in Pabbly Connect. Select Cashfree from the list of applications and choose the trigger event as ‘Payment via Form’. This will initiate the workflow every time a payment is made.
Next, you’ll need to connect Cashfree to Pabbly Connect by providing a webhook URL. This URL acts as a bridge for communication between the two platforms. Copy the webhook URL generated by Pabbly Connect and paste it into your Cashfree account under the Webhooks settings.
- Log into Cashfree and navigate to ‘Webhooks’.
- Add a new webhook endpoint using the copied URL.
- Test and save your settings.
After setting this up, you will test the webhook connection by making a payment through Cashfree. Ensure that the payment data is captured in Pabbly Connect.
4. Configuring Kit as Action in Pabbly Connect
Now that the trigger is set, we will configure the action application, which is Kit. Select Kit from the application list and choose the action event as ‘Create Subscriber’. This step will allow you to create a new subscriber in your Kit account based on the payment information received from Cashfree.
To connect Kit with Pabbly Connect, you will need the API key and API secret from your Kit account. Navigate to your Kit account settings, copy the necessary credentials, and paste them into Pabbly Connect to establish the connection.
Select the tag for the subscriber (e.g., Cashfree). Map the email, first name, last name, and phone number from the Cashfree payment response. Click ‘Save and Send Test Request’ to finalize the setup.
After completing these steps, verify that the subscriber has been created in your Kit account with the correct details.
After setting up both the trigger and action, it’s crucial to test the entire workflow to ensure that everything functions as expected. Make a test payment through your Cashfree account, using dummy details to simulate a real transaction.
Once the payment is successful, check your Kit account to confirm that the subscriber has been created. You should see the new subscriber listed under the specified tag, indicating that the integration via Pabbly Connect is working correctly.
To summarize:
Make a payment through Cashfree. Verify the subscriber creation in Kit. Ensure all details are accurately captured.
If the subscriber appears as expected, your automation is successfully set up, and you can now enjoy the benefits of automated subscriber creation with every payment received.
In this tutorial, we explored how to create a Kit subscriber on Cashfree payment using Pabbly Connect. By following the steps outlined, you can automate the process of subscriber creation, saving time and reducing manual effort. This integration enhances your workflow efficiency and ensures that all payment transactions are seamlessly captured in your Kit account.
