Learn how to integrate Typeform with GoHighLevel using Pabbly Connect to automatically create contacts from form submissions. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To create a GoHighLevel contact from Typeform, you first need to access Pabbly Connect. This platform allows you to set up the integration between Typeform and GoHighLevel seamlessly. If you are an existing user, simply sign in. For new users, you can sign up for free and access 100 tasks per month.
Once logged in, navigate to the applications page and click on Pabbly Connect to access your dashboard. Here, you can create a new workflow to manage your automation between Typeform and GoHighLevel.
In your Pabbly Connect dashboard, look for the ‘Create Workflow’ button on the right-hand corner. Click on it to open a dialog box where you can name your workflow. For this integration, name it ‘Create GoHighLevel Contact from Typeform’ and select the appropriate folder to save it in.
After naming your workflow, click on the ‘Create’ button. You will now see a window that prompts you to set up your trigger and action. In this case, Typeform will be your trigger application, and the action application will be GoHighLevel.
3. Setting Up Typeform as the Trigger Application
To set up Typeform as your trigger application in Pabbly Connect, search for ‘Typeform’ in the trigger window. Select it, and then choose the trigger event as ‘New Entry.’ This event will activate every time a new form submission occurs.
Next, you need to connect your Typeform account to Pabbly Connect. Click on ‘Connect’ and then select ‘Connect with Typeform.’ Authorize the connection to allow Pabbly Connect to access your Typeform data. Once connected, select the form you want to use for this integration.
- Click the dropdown and select your form, such as ‘Travel Contact Form.’
- Click on ‘Save and Send Test Request’ to capture the response.
After submitting a test entry through your Typeform, you will see the response captured in Pabbly Connect, confirming that your trigger setup is successful.
4. Creating a Contact in GoHighLevel
Now that you have successfully set up Typeform as your trigger, it’s time to create a contact in GoHighLevel using Pabbly Connect. In the action window, search for ‘GoHighLevel’ and select it as your action application. Choose the action event as ‘Create Contact’ to proceed.
Next, you will need to connect your GoHighLevel account to Pabbly Connect. Click on ‘Connect’ and authorize the connection. Once authorized, you will need to map the fields from the Typeform response to the corresponding fields in GoHighLevel.
- Map the first name, last name, email, and phone number from the Typeform response.
- Ensure all necessary fields are filled to create the contact successfully.
After mapping the fields, click on ‘Save and Send Test Request’ to create the contact. You should receive a positive response confirming that the contact has been created in GoHighLevel.
5. Conclusion: Automating Contacts with Pabbly Connect
Using Pabbly Connect to integrate Typeform with GoHighLevel streamlines the process of creating contacts from form submissions. This automation ensures that every new entry in your Typeform is instantly added to your GoHighLevel CRM, enhancing efficiency in managing customer data.
By following these steps, you can easily set up this integration, allowing your travel and tourism business to capture leads effectively. Embrace the power of automation with Pabbly Connect and improve your business operations today.
