Learn how to integrate ActiveCampaign with GoHighLevel using Pabbly Connect to automate the creation of contacts for tagged ActiveCampaign contacts. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
1. Introduction to Pabbly Connect for Integration
In this section, we will explore how to use Pabbly Connect to integrate ActiveCampaign with GoHighLevel. This integration allows you to automatically create contacts in GoHighLevel whenever a new contact is tagged in ActiveCampaign. This automation simplifies your workflow and ensures that all tagged contacts are captured efficiently.
To start, navigate to the Pabbly Connect dashboard after signing in. If you are a new user, you can sign up for free to access various automation features. Once logged in, you can begin setting up your integration workflow.
To create your workflow in Pabbly Connect, click on the ‘Create Workflow’ button on the dashboard. You will be prompted to select a folder and name your workflow. For this integration, name it ‘GoHighLevel Contacts for Tagged ActiveCampaign Contacts’ and choose a suitable folder, like ‘Automations’.
- Click on the ‘Create’ button to open the workflow window.
- This window allows you to set up triggers and actions for your automation.
In this workflow, you will set ActiveCampaign as the trigger application and GoHighLevel as the action application. This setup ensures that whenever a contact is tagged in ActiveCampaign, the relevant details are automatically sent to GoHighLevel.
3. Setting Up the Trigger with ActiveCampaign
For the trigger in Pabbly Connect, select ActiveCampaign and choose ‘Contact Tag Added’ as the trigger event. This selection means that the workflow will activate whenever a new tag is added to a contact in ActiveCampaign.
Next, you need to connect your ActiveCampaign account. Click on ‘Add New Connection’ and input your API key and URL. To find these, log into your ActiveCampaign account, navigate to the ‘Settings’ tab, and then select ‘Developers’. Copy the URL without the ‘https://’ and the API key, and paste them into Pabbly Connect.
4. Configuring the Action with GoHighLevel
After successfully setting up the trigger, the next step in Pabbly Connect is to configure the action application, which is GoHighLevel. Select ‘Lead Connector V1’ as the action application and choose ‘Create or Update Contact’ as the action event.
Similar to the trigger setup, you will need to connect your GoHighLevel account. Click on ‘Add New Connection’ and enter your API key from GoHighLevel. To find this, log into your GoHighLevel account, go to ‘Settings’, and locate the API key section. Copy and paste this key into Pabbly Connect and click ‘Save’.
- Map the necessary fields such as first name, last name, email, and phone number from the ActiveCampaign trigger response.
- Ensure to include the tag in quotation marks as specified in the workflow.
Once all fields are mapped, click on ‘Save and Send Test Request’ to check if the integration is working correctly. A positive response indicates that a new contact has been successfully created in GoHighLevel.
Now that you have set up the integration in Pabbly Connect, it’s time to test it. Go back to your ActiveCampaign account and tag a new contact with the desired tag. This action will trigger the workflow you created.
After tagging the contact, return to Pabbly Connect to see if the response was captured. If successful, the new contact will appear in your GoHighLevel account. This confirms that the integration is functioning as intended.
You can repeat the tagging process with different contacts to ensure consistent results. This automation saves time by eliminating manual entry of contacts.
By following these steps, you can successfully automate the process of creating contacts in GoHighLevel for tagged ActiveCampaign contacts using Pabbly Connect.
In this tutorial, we demonstrated how to integrate ActiveCampaign with GoHighLevel using Pabbly Connect. This integration streamlines your workflow by automatically creating contacts in GoHighLevel whenever a contact is tagged in ActiveCampaign. By automating this process, you save time and ensure accurate data management.
