Learn how to integrate GoHighLevel and ActiveCampaign using Pabbly Connect. Follow our step-by-step guide to automate contact creation seamlessly. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
In this section, we will discuss how to access Pabbly Connect to set up the integration between ActiveCampaign and GoHighLevel. First, navigate to the Pabbly website and sign up for a new account or log in if you are an existing user.
Once logged in, you will see various Pabbly applications. Click on Pabbly Connect to access the dashboard where you can create workflows. This is the central hub for managing your integrations.
To create a workflow in Pabbly Connect, click on the ‘Create Workflow’ button on your dashboard. You will be prompted to choose a folder for saving your workflow and to name the workflow.
- Select the folder named ‘Automations’.
- Name your workflow as ‘GoHighLevel Contacts for Tagged ActiveCampaign Contact’.
After naming your workflow, click on the ‘Create’ button. This opens the workflow window, where you will set up the trigger and action for your automation.
In this step, we will set up the trigger in Pabbly Connect. Select ActiveCampaign as the trigger application and choose the event ‘Contact Tag Added’ as the trigger event. This means that whenever a tag is added to a contact in ActiveCampaign, it will trigger the workflow.
Next, click on ‘Connect’ and choose to add a new connection. You will need to provide your ActiveCampaign API key and URL, which you can find in your ActiveCampaign account under Settings > Developer. Ensure to remove ‘https://’ from the URL before saving.
4. Configuring the Action in Pabbly Connect
For the action step, select GoHighLevel as the action application and choose ‘Create or Update Contact’ as the action event. Click on ‘Connect’ again and add a new connection by entering your GoHighLevel API key. using Pabbly Connect
After connecting, you will need to map the details from the ActiveCampaign trigger to the GoHighLevel action. This includes mapping the first name, last name, email, phone number, and the tag. Make sure to format the tag correctly by placing it within quotation marks.
- Map the first name and last name from the trigger response.
- Map the email and phone number accordingly.
- Finally, map the tag as ‘GoHighLevel’.
Click on ‘Save and Send Test Request’ to test the integration. You should receive a positive response indicating that a new contact has been created in GoHighLevel.
5. Testing the Integration with ActiveCampaign
To ensure that your workflow is functioning correctly, go back to your ActiveCampaign account and tag a contact. This action will trigger the workflow you set up in Pabbly Connect.
After tagging the contact, check your GoHighLevel account to confirm that the new contact has been created. This verifies that the integration between ActiveCampaign and GoHighLevel through Pabbly Connect is successful.
By following these steps, you can automate the process of creating contacts in GoHighLevel whenever a tagged contact is added in ActiveCampaign, streamlining your workflow efficiently.
This tutorial demonstrates how to integrate ActiveCampaign with GoHighLevel using Pabbly Connect. By setting up triggers and actions, you can automate contact creation effectively, ensuring your workflows run seamlessly.
