Learn how to automate GitHub issue creation from Typeform submissions using Pabbly Connect. Step-by-step guide to streamline your workflow. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
1. Setting Up Pabbly Connect for Typeform and GitHub Integration
To create GitHub issues from Typeform submissions, you must first access Pabbly Connect. Start by visiting the Pabbly Connect website and signing in or signing up for a new account. This platform allows you to automate workflows without any coding skills.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you will find options to create a new workflow. Click on the ‘Create Workflow’ button, name your workflow (e.g., ‘Create GitHub Issue from Typeform Submission’), and select a folder to save it. This sets the stage for integrating Typeform and GitHub through Pabbly Connect.
2. Setting Up Typeform as the Trigger in Pabbly Connect
In this step, you will configure Typeform as the trigger application in Pabbly Connect. Click on the trigger box and select Typeform from the list of applications. The trigger event will be set to ‘New Entry’, which means every time a new form submission is made, it will activate the workflow.
- Select the Typeform application as your trigger.
- Choose ‘New Entry’ as the trigger event.
- Connect your Typeform account to Pabbly Connect by clicking on the connect button and following the prompts.
After setting up the trigger, you will need to select the specific Typeform you want to use for this integration. Once chosen, click on ‘Save and Send Test Request’ to ensure that your connection is functioning correctly. This will allow Pabbly Connect to receive data from new submissions.
3. Configuring GitHub as the Action in Pabbly Connect
Now that you have set up Typeform as the trigger, it’s time to configure GitHub as the action application in Pabbly Connect. Click on the action box and select GitHub from the list of applications. The action event will be ‘Create Issue’, which means that every time a new entry is submitted in Typeform, a new issue will be created in GitHub.
Next, connect your GitHub account to Pabbly Connect. Click on the connect button, authorize the connection, and select the repository where the issue will be created. You will also need to map the issue title and description from the Typeform submission to the corresponding fields in GitHub.
- Select GitHub as your action application.
- Choose ‘Create Issue’ as the action event.
- Map the fields for issue title and description using the data from the Typeform submission.
After mapping the fields, click on ‘Save and Send Test Request’ to create a test issue in GitHub. This confirms that your integration is working correctly through Pabbly Connect.
4. Testing the Integration Between Typeform and GitHub
Once you have set up both the trigger and action, it’s essential to test the integration. Fill out the Typeform issue form with sample data, including your name, email, issue title, and description. After submitting the form, Pabbly Connect will receive this data and create a corresponding issue in GitHub.
Navigate to your GitHub account and check the issues section to confirm that the new issue appears with the correct title and description. This step is crucial to ensure that the automation process is functioning as expected. If the issue is created successfully, your integration is complete.
5. Finalizing Your Pabbly Connect Workflow
After successfully testing the integration, finalize your workflow in Pabbly Connect. You can now manage the workflow settings, such as enabling or disabling it as needed. Whenever a new submission is made on Typeform, a new issue will automatically be created in GitHub without any manual intervention.
This automation saves time and ensures that all issues are tracked efficiently. You can also revisit and modify your workflow anytime in Pabbly Connect to adapt to changing needs or additional features. By using Pabbly Connect, you have streamlined your issue tracking process.
This tutorial demonstrated how to use Pabbly Connect to automate the creation of GitHub issues from Typeform submissions. By following these steps, you can enhance your workflow and ensure that all user issues are tracked seamlessly.
