Learn how to automate Facebook and LinkedIn posts for WooCommerce product updates using Pabbly Connect. Step-by-step tutorial with detailed instructions. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To automate Facebook and LinkedIn posts for WooCommerce product updates, you need to access Pabbly Connect. Start by visiting the Pabbly Connect dashboard after signing up or logging in.
Once on the dashboard, click on the ‘Create Workflow’ button. Here, you will name your workflow, such as ‘Create Facebook Page Post and LinkedIn Company Text Post for Product Update in WooCommerce.’ This sets the stage for the integration process.
2. Setting Up the Trigger Event in Pabbly Connect
The next step involves defining the trigger event in Pabbly Connect. Your trigger application will be WooCommerce, and the trigger event will be ‘Product Updated.’ This means every time a product is updated, the workflow will execute.
- Select WooCommerce as the trigger application.
 - Choose ‘Product Updated’ as the trigger event.
After copying the webhook URL, navigate to your WooCommerce settings to set up the webhook. This URL will enable communication between WooCommerce and Pabbly Connect.
3. Configuring the V Commerce Webhook
In this step, you will configure the webhook in V Commerce to link it with Pabbly Connect. Go to the settings in your V Commerce account, find the Advanced section, and click on Webhooks.
Click on ‘Add Webhook’ and fill in the necessary details:
- Name: Test Integration 123
 - Status: Active
 - Topic: Product Updated
 - Delivery URL: Paste the copied webhook URL
Save the webhook settings, and then click on ‘Recapture Webhook Response’ in Pabbly Connect to ensure it is ready to receive data from WooCommerce.
4. Setting Up Action Applications in Pabbly Connect
Now, you will set up the action applications in Pabbly Connect. The first action application will be LinkedIn, where you will create a company text post.
Select LinkedIn as the action application, and choose ‘Create Company Text Post’ as the action event. Connect your LinkedIn account to Pabbly Connect to allow posting on your company page.
Map the product name received from the webhook. Enter a message for the post, such as ‘Product update alert: [Product Name].’ Include the product URL for more details.
Once you fill in these details, save the action and test the request to ensure the post appears correctly on LinkedIn.
5. Posting to Facebook Using Pabbly Connect
The final step is to create a Facebook page post using Pabbly Connect. Add another action step and select Facebook Pages as the application.
Choose ‘Create Page Post’ as the action event and connect your Facebook account. Fill in the page message and link URL just like you did for LinkedIn.
Select the Facebook page where you want to post. Map the same product update message. Add the product URL for the post.
Once everything is set up, save and send the test request to confirm that the post appears on your Facebook page as expected. This completes the integration process using Pabbly Connect.
In this tutorial, we demonstrated how to automate Facebook and LinkedIn posts for WooCommerce product updates using Pabbly Connect. By following these steps, you can easily keep your audience informed about product changes.
