Learn how to create dynamic web pages and redirect users using form submission data with Pabbly Connect. Step-by-step tutorial for seamless integration. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
1. Introduction to Pabbly Connect for Dynamic Web Pages
Pabbly Connect is a powerful integration platform that enables users to create dynamic web pages and redirect users based on form submission data. By using Pabbly Connect, you can automate the process of redirecting users to dynamically generated web pages after they fill out a form.
In this tutorial, we will walk through the steps of setting up Pabbly Connect, integrating it with Elementor forms, and redirecting users to a custom web page. This process will not require any coding skills, making it accessible for everyone.
2. Setting Up Pabbly Connect
To get started, visit Pabbly.com and sign up for a free account. Once you have signed in, navigate to the Pabbly Connect dashboard to begin creating your workflow.
Follow these steps to set up your Pabbly Connect integration:
- Name your workflow, for example, ‘Create Dynamic Web Pages on Form Submission.’
- Select ‘Elementor Forms’ as the trigger app.
After setting up the trigger, you will receive a webhook URL. This URL will be used to connect your Elementor form with Pabbly Connect.
3. Configuring Elementor Forms with Pabbly Connect
Now that you have your webhook URL, it’s time to configure your Elementor form to send data to Pabbly Connect. Edit your booking form using Elementor and navigate to the form settings.
In the form settings, locate the ‘Actions After Submit’ option and add two actions:
- Collect Submissions
- Redirect
For the redirect action, paste the webhook URL from Pabbly Connect into the redirect field. Make sure to append the parameters for the fields you want to send, such as name, email, and message, to the end of the URL.
Once you have configured your Elementor form, it’s time to test the integration. Fill out the form with test data and submit it. Pabbly Connect will capture this submission through the webhook. using Pabbly Connect
To validate the data, go back to your Pabbly Connect dashboard and check if the submission data appears correctly. If the data is captured, you are ready to proceed to the next step of generating the dynamic web page.
In this step, you will also set up a random number generator to assign table numbers for your event. Use the ‘Number Formatter’ action in Pabbly Connect to create random numbers between 100 and 1000, which will serve as table numbers for your concert attendees.
5. Creating Dynamic Web Pages and Redirecting Users
After successfully capturing form submissions and generating random table numbers, the next step is to create the dynamic web page. Use the ‘Dynamic Web Pages’ action in Pabbly Connect to generate a unique web page URL for each submission. using Pabbly Connect
In the HTML content field, input the custom HTML code for your dynamic page. Make sure to map the user’s name and randomly generated table number into the HTML code for personalization. For example, your HTML should greet the user by name and provide a download link for their ticket.
Finally, set up a redirect to send users to this newly created page. Use the ‘Data Forwarder’ action in Pabbly Connect to redirect users to the generated web page URL. Ensure that you set the redirect status to ‘moved permanently’ for optimal SEO performance.
Using Pabbly Connect, you can effortlessly create dynamic web pages and redirect users based on form submission data. This tutorial has outlined the steps needed to set up the integration with Elementor forms, generate personalized web pages, and automate the redirection process. By leveraging Pabbly Connect, you can enhance user experience and streamline your event management process.
