Learn how to automate the process of creating AWeber subscribers from Typeform submissions using Pabbly Connect. Follow this detailed step-by-step tutorial. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
1. Accessing Pabbly Connect for Typeform and AWeber Integration
To start automating the process of creating AWeber subscribers from Typeform submissions, first, access Pabbly Connect. This platform allows you to connect different applications without any coding knowledge.
Visit the Pabbly Connect website by typing Pabbly.com/connect in your browser. Here, you have options to sign in or sign up for free. New users can create an account in just two minutes and receive 100 free tasks each month to explore the platform.
Once logged into Pabbly Connect, navigate to the dashboard to create a new workflow. Click on the ‘Create Workflow’ button, and a dialog box will appear asking for a workflow name.
Enter a descriptive name such as ‘Create AWeber Subscriber on Typeform Submission’. Select the appropriate folder for your workflow, like ‘Automations for Lead Management’, and click on ‘Create’. You will then see the trigger and action setup screen.
- Select the right folder to organize your workflows.
Now, you are ready to select the trigger application and action to automate the process.
3. Setting Up the Trigger for Typeform Submissions
In this step, you will set Typeform as your trigger application in Pabbly Connect. Select ‘Typeform’ and then choose the trigger event as ‘New Entry’. This will initiate the workflow whenever a new form is submitted.
To connect Typeform with Pabbly Connect, select ‘Add New Connection’. You will be prompted to log into your Typeform account. Once logged in, grant the necessary permissions to allow Pabbly Connect to access your Typeform data.
- Select ‘Typeform’ as the trigger application.
- Choose ‘New Entry’ as the trigger event.
- Authorize Pabbly Connect to access your Typeform account.
After authorization, select the specific form you want to connect, like the ‘Registration Form’. Click on ‘Save and Send Test Request’ to capture the response.
4. Setting Up the Action to Create AWeber Subscriber
Now that the trigger is set, it’s time to configure the action step in Pabbly Connect to create a subscriber in AWeber. Select ‘AWeber’ as your action application and choose the event ‘Add or Update Subscriber’.
Similar to the trigger setup, you will need to create a new connection to your AWeber account. Click on ‘Add New Connection’ and authorize Pabbly Connect to access your AWeber data. Once connected, you will fill in the subscriber details using the data captured from the Typeform submission.
Select ‘AWeber’ as the action application. Choose ‘Add or Update Subscriber’ as the action event. Map the fields like name, email, and phone number from Typeform to AWeber.
Ensure that you enable the option to update existing subscribers if they already exist in AWeber. After mapping all necessary fields, click on ‘Save and Send Test Request’ to finalize the setup.
After setting up the workflow in Pabbly Connect, it’s crucial to test the integration. Go back to your Typeform and submit a test entry using the form. This will ensure that the data is captured correctly and that the subscriber is added to your AWeber account.
Check your AWeber account to confirm that the new subscriber appears in the subscriber list. Repeat this process with different test entries to ensure everything functions smoothly. With this automation, every new entry in Typeform will automatically create or update a subscriber in AWeber.
Submit a test entry in Typeform. Verify that the subscriber is created in AWeber. Repeat with different entries to ensure reliability.
Once confirmed, your integration is complete, and you can now manage your email marketing efficiently using Pabbly Connect.
In this tutorial, we explored how to create AWeber subscribers from Typeform submissions using Pabbly Connect. This automation streamlines your lead management process, allowing you to focus on converting leads into customers effortlessly.
By following these detailed steps, you can ensure that every lead captured through Typeform is automatically added to your AWeber account, enhancing your email marketing efforts.
