Learn how to automate the process of creating AWeber subscribers from Cashfree payments using Pabbly Connect. Step-by-step tutorial included. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
1. Introduction to Pabbly Connect for Integration
Pabbly Connect is a powerful tool that facilitates the integration of various applications, including Cashfree and AWeber. In this tutorial, we will automate the process of creating an AWeber subscriber whenever a payment is made through Cashfree.
This automation eliminates the need for manual entry, saving time and reducing errors. By using Pabbly Connect, we can seamlessly connect these two platforms and streamline our workflow.
2. Setting Up Your Pabbly Connect Workflow
To initiate the integration process, first, log in to your Pabbly Connect account. If you are a new user, you can sign up for free and get started with 100 free tasks every month. Once logged in, you will see various applications available for integration.
Next, click on the ‘Create Workflow’ button in the top right corner. In the dialog box that appears, name your workflow as ‘Create AWeber Subscriber on Cashfree Payment’ and select a folder to save it. Here’s how to do this:
- Click on ‘Create Workflow’
- Name your workflow
- Select a folder for saving
After setting this up, click the ‘Create’ button to finalize your workflow. You will now see a trigger and action setup.
3. Configuring the Trigger with Cashfree
In the trigger section, select Cashfree as your trigger application. The trigger event to choose is ‘Payment via Form’. This means that every time a payment is made through Cashfree, it will trigger the workflow in Pabbly Connect.
To connect Cashfree to Pabbly Connect, copy the webhook URL provided. Log into your Cashfree account, navigate to the Developers section, and click on Webhooks. Then, add a new webhook endpoint using the copied URL:
- Go to Developers > Webhooks
- Click on ‘Add Webhook Endpoint’
- Paste the copied URL and click ‘Test and Add’
Once added, refresh the Cashfree page to confirm the webhook is set up correctly. This establishes the connection between Cashfree and Pabbly Connect.
4. Performing a Test Payment
To ensure that the integration works properly, perform a test payment using the Cashfree payment form. Fill in the required customer details such as name, email, and payment method. After completing the payment, return to your Pabbly Connect workflow to check if the payment details have been captured successfully.
During this step, ensure that the response from Cashfree includes all necessary customer information. You should see fields like transaction ID, status, and customer details:
Transaction ID Payment Status Customer Name and Email
If the data appears correctly in your workflow, this confirms that Cashfree is successfully connected to Pabbly Connect.
5. Adding Subscriber in AWeber
Now that the trigger is set, it’s time to configure the action step to add the subscriber in AWeber. Select AWeber as your action application and choose the event ‘Add or Update Subscriber’. This ensures that every new payment will automatically create a new subscriber in your AWeber account.
Connect your AWeber account by clicking on ‘Connect with AWeber’ and authorize Pabbly Connect to access your account. After connecting, map the fields from the Cashfree response to the AWeber fields:
Map Customer Name to Full Name Map Email Address Select List ID for Subscribers
Finally, click on ‘Save and Send Test Request’ to finalize the setup. After refreshing your AWeber account, check if the new subscriber has been added successfully, confirming that the integration works flawlessly through Pabbly Connect.
In this tutorial, we demonstrated how to automate the process of creating AWeber subscribers from Cashfree payments using Pabbly Connect. This integration streamlines your workflow, allowing for efficient customer engagement without manual effort. By following these steps, you can enhance your email marketing strategy effectively.
