Learn how to integrate Apollo.io with Wix Forms Submission using Pabbly Connect for seamless automation. Step-by-step tutorial included. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To create an Apollo.io contact on Wix Forms submission, first, access Pabbly Connect. This platform enables seamless integration between your Wix Forms and Apollo.io without any coding skills.
Begin by navigating to the Pabbly Connect website. If you are a new user, sign up for a free account. Existing users can simply sign in. Once logged in, you will reach the Pabbly Connect dashboard where you can manage your workflows.
2. Setting Up Wix Forms Submission Trigger
Next, set up your Wix Forms as the trigger in Pabbly Connect. This means that every time a form is submitted, it will initiate the workflow.
- Click on ‘Create Workflow’ in Pabbly Connect.
- Choose ‘Wix Forms’ as your trigger application.
- Select ‘Form Submitted’ as the trigger event.
After selecting the trigger, you will need to connect your Wix account. This involves providing the necessary permissions for Pabbly Connect to access your Wix Forms data.
3. Connecting Apollo.io as Action Application
Once your Wix Forms trigger is set, the next step is to connect Apollo.io as the action application in Pabbly Connect. This step ensures that every new form submission creates a contact in Apollo.io.
Select ‘Apollo.io’ as the action application and choose ‘Create Contact’ as the action event. You will then enter your Apollo.io API key to establish a connection.
- Copy your API key from the Apollo.io dashboard.
- Paste it into Pabbly Connect when prompted.
- Map the fields from Wix Forms to Apollo.io, ensuring each field corresponds correctly.
This mapping is crucial as it defines how data from the Wix form will populate the fields in Apollo.io.
4. Testing the Integration
After setting up the connection, it’s essential to test the integration using Pabbly Connect. This step verifies that the workflow functions as intended.
Submit a test entry through your Wix form. After submission, check Pabbly Connect for a response indicating a successful connection. You should see the test data reflected in your Apollo.io account.
Ensure that the contact details such as first name, last name, email, and other relevant fields are correctly populated. If everything appears accurate, your integration is successful!
5. Conclusion
In conclusion, using Pabbly Connect to automate the creation of Apollo.io contacts from Wix Forms submissions streamlines your workflow. This integration enhances efficiency by eliminating manual data entry, allowing you to focus on growing your business.
With the steps outlined above, you can easily set up this automation and enjoy the benefits of seamless data transfer between your applications.
