Learn how to automate sending Telegram chat invite links upon Stripe subscription using Pabbly Connect. Step-by-step tutorial included. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Setting Up Pabbly Connect for Stripe and Telegram Integration
In this section, we will set up Pabbly Connect to automate the process of sending a Telegram chat invite link when a new subscription is created in Stripe. First, access your Pabbly Connect account and create a new workflow by clicking on the ‘Create Workflow’ button. Name your workflow, for example, ‘Stripe to Telegram to Gmail.’ Select the appropriate folder for your workflow and click on ‘Create’.
Once the workflow is created, you will see two sections: the Trigger and Action windows. The Trigger window is where we will connect Stripe to Pabbly Connect. This will allow Pabbly Connect to capture subscription events from Stripe whenever a customer subscribes to your product.
2. Connecting Stripe to Pabbly Connect
To connect Stripe with Pabbly Connect, select Stripe as the app in the Trigger section. Choose the trigger event as ‘New Subscription’. After selecting this, Pabbly Connect will provide you with a webhook URL. Copy this URL as you will need to add it to your Stripe account to establish the connection.
- Go to your Stripe account and navigate to the ‘Developers’ section.
- Click on ‘Settings’ and then on ‘Webhooks’.
- Click on ‘Add Endpoint’ and paste the webhook URL from Pabbly Connect.
- Select the event ‘customer.subscription.created’ to receive subscription details.
After adding the webhook URL, click on ‘Create Endpoint’. This successfully connects your Stripe account with Pabbly Connect. The next step is to test this connection by making a test subscription in Stripe.
3. Generating the Telegram Chat Invite Link
After successfully connecting Stripe to Pabbly Connect, the next step is to generate a Telegram chat invite link. For this, we will use the Telegram Bot API. First, you need to create a bot using the BotFather in Telegram. Once created, copy the API token provided by the BotFather.
In Pabbly Connect, add a new action step and select the Telegram Bot app. Choose the action event as ‘Create Chat Invite Link’. Connect your Telegram bot by pasting the API token you copied earlier. Make sure to add this bot to your Telegram group and promote it to admin to allow it to generate invite links.
4. Sending the Email with the Invite Link via Gmail
Now that we have the Telegram invite link, we need to send an email to the customer who subscribed. For this, add another action step in Pabbly Connect and select Gmail as the app. Choose the action event ‘Send Email’. Connect your Gmail account and fill in the required fields such as recipient email, subject, and body.
In the email body, include the invite link generated from the Telegram Bot step. You can personalize the email by mapping the customer’s name and adding a welcome message. This email will automatically be sent to the customer after they subscribe through Stripe.
5. Conclusion
In conclusion, using Pabbly Connect allows you to seamlessly integrate Stripe with Telegram and Gmail. This automation ensures that whenever a new subscription is created in Stripe, a personalized Telegram invite link is generated and sent to the customer via email. This not only enhances customer experience but also streamlines your communication process.
With Pabbly Connect, you can easily set up similar automations for various applications to improve your business workflows. Start using Pabbly Connect today to automate your tasks efficiently!
