Learn how to use Pabbly Connect to automate the creation of AI-generated ad copy with Google Sheets and OpenAI. Streamline your ad copy process today!
To create and draft AI-generated ad copy effortlessly, start by accessing Pabbly Connect. Open your browser and enter the URL for Pabbly Connect. If you are a new user, click on ‘Sign Up for Free’ to create an account. Existing users can simply click on ‘Sign In’.
Once you are signed in, you will see all the applications offered by Pabbly. Click on ‘Access Now’ for Pabbly Connect. This will take you to your dashboard where you can create workflows that will automate the ad copy generation process.
Now, to set up your automation, click on the ‘Create Workflow’ button in Pabbly Connect. You will be prompted to name your workflow. For this tutorial, name it ‘How to Create and Draft AI-Generated Ad Copy Effortlessly with AI Agent’. After naming, click on ‘Create’.
This opens the workflow window, where you can set up your trigger and action. The trigger is the event that starts the automation, while actions are what happen in response. For our example, we will select Google Sheets as the trigger application.
- Select Google Sheets as the trigger application.
- Choose ‘New or Updated Spreadsheet Rows’ as the trigger event.
- Copy the provided webhook URL for later use.
After completing these steps, you will have set the foundation for your automation using Pabbly Connect.
3. Setting Up Google Sheets with Pabbly Connect
Next, open your Google Sheets where you have the ad details. Go to ‘Extensions’, then ‘Add-ons’, and select ‘Get Add-ons’. Search for ‘Pabbly Connect Webhooks’ and install it. After installation, refresh your spreadsheet to enable the add-on.
Once refreshed, navigate back to ‘Extensions’ and select ‘Pabbly Connect Webhooks’. From there, click on ‘Initial Setup’. Paste the webhook URL you copied earlier into the designated field and specify the trigger column where data will be entered (for example, column E).
- Paste the webhook URL in the setup field.
- Specify the trigger column based on your spreadsheet setup.
- Click ‘Submit’ to save your configuration.
Now, your Google Sheets is successfully connected to Pabbly Connect, ready to send data to your automation workflow.
4. Testing the Automation with Pabbly Connect
To test the automation, you need to send a test submission. Go back to your Google Sheets and enable the ‘Send on Event’ option in the Pabbly Connect Webhooks menu. This ensures that any new entry in the specified column will trigger the webhook.
Enter your ad details in the specified columns (Ad ID, Product Name, Target Audience, Key Features, and CTA). Once this information is entered, it will trigger the webhook to send data to Pabbly Connect.
Enter all necessary ad details in your Google Sheets. Check if the webhook captures the response correctly. Confirm that the data appears in Pabbly Connect.
Once the test submission is successful, you can move on to the next step of generating the ad copy using your AI agent.
5. Generating Ad Copy with AI Agent in Pabbly Connect
In this step, select OpenAI as your action application in Pabbly Connect. Choose ‘Chat GPT’ as the action event. If you haven’t connected your OpenAI account yet, you will need to add a new connection by providing your API key.
To obtain your API key, go to your OpenAI account and create a new secret key. Copy the generated key and paste it into the Pabbly Connect workflow. After connecting, you can set the AI model (e.g., GPT-4) and enter your prompt for ad copy generation.
Select OpenAI as the action application. Enter your prompt and map the details from Google Sheets. Click ‘Save and Send Test Request’ to generate the ad copy.
After executing this step, your AI agent will generate the ad copy based on the details you provided. The generated content will then be ready for review in your Google Sheets.
Using Pabbly Connect, you can automate the process of generating AI-driven ad copy seamlessly. This integration with Google Sheets and OpenAI allows for efficient ad creation, saving you time and effort. Start automating your ad copy process today!
