Learn how to create an AI agent that generates images in Trello cards using Pabbly Connect. Step-by-step guide to integrate Trello and OpenAI seamlessly. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
1. Accessing Pabbly Connect for AI Image Generation
To create an AI agent that generates images in Trello cards, you first need to access Pabbly Connect. Start by opening your browser and navigating to the Pabbly Connect landing page.
Once there, you will see two options: ‘Sign In’ and ‘Sign Up Free.’ If you are new to Pabbly Connect, click on ‘Sign Up Free’ to create your account. After signing in, click on ‘Access Now’ under Pabbly Connect to enter the dashboard.
After accessing the dashboard, the next step is to create a new workflow for your AI agent. Click on the ‘Create Workflow’ button and provide a name for your workflow, such as ‘AI Agent for Trello Image Generation.’ Select the appropriate folder within your Pabbly Connect account and click on ‘Create’ to proceed. using Pabbly Connect
  • Click on ‘Create Workflow’.
  • Name your workflow accordingly.
  • Select the desired folder for your workflow.
Once the workflow is created, you will see the trigger and action windows. The trigger is where you set the event that starts the workflow, while the action is what happens as a result. In this case, the trigger will be a new card added to Trello.
3. Setting Up Trello Trigger in Pabbly Connect
To set up the Trello trigger, you will select Trello as the application in the trigger window. Choose the trigger event as ‘New Card Added’ and then click on ‘Connect’ to establish a connection with your Trello account. using Pabbly Connect
To connect Trello, you will need to enter your Trello username, API key, and token. You can find your username in your Trello profile settings. For the API key and token, navigate to the Trello developer key section and follow the instructions to generate them.
  • Select Trello as the application.
  • Choose ‘New Card Added’ as the trigger event.
  • Enter your Trello account details to establish the connection.
After connecting, select the Trello board and the specific list from which you want to capture new cards. Once you’ve done this, click on ‘Save and Send Test Request’ to confirm the connection.
4. Filtering Trigger Events for New Cards
After setting up the trigger, you will need to filter the events to ensure that the AI agent only responds to new card creations. Click on the action step and select the ‘Filter by Pabbly’ option. using Pabbly Connect
Set the filter type to ‘Equals to’ and specify the value as ‘action_create_card’. This step is crucial to prevent the AI agent from triggering for any other updates to existing cards.
Select ‘Filter by Pabbly’ in the action step. Set filter type to ‘Equals to’. Enter the value as ‘action_create_card’.
Once the filter is set up, click on ‘Save and Send Test Request’ to verify that it is functioning correctly. This ensures that your AI agent will only act on new cards added to Trello.
5. Generating Images with OpenAI
With the trigger and filtering steps complete, the next action is to send the card title to OpenAI to generate an image. In the action step, select OpenAI and choose ‘Generate Image’ as the action event. Connect your OpenAI account by entering your API key, which can be generated from your OpenAI dashboard. using Pabbly Connect
In the OpenAI action settings, map the prompt to the card title captured from Trello. Specify the number of images to generate and the desired size, such as HD. Click on ‘Save and Send Test Request’ to generate the image based on the prompt.
Select OpenAI and choose ‘Generate Image’. Map the prompt to the card title from Trello. Specify image settings and click ‘Save and Send Test Request’.
Once the image is generated, you will receive a response containing the image URL. This URL will be used in the final step to update the Trello card with the generated image.
Conclusion: Updating Trello Card with Generated Image
In the final step, you will update the Trello card with the generated image. Select Trello again in the action step and choose ‘Create Attachment on Card’ as the action event. Connect to your existing Trello account and select the same board and list as before.
Map the card ID from the trigger step to ensure the image is attached to the correct card. Then, provide the image URL received from OpenAI as the attachment URL. Click on ‘Save and Send Test Request’ to complete the workflow.
After successfully running the workflow, check your Trello board to see the generated image attached to the corresponding card. This integration showcases the power of Pabbly Connect in automating tasks between Trello and OpenAI seamlessly.
