Learn to automate your WordPress posts using AI agents with Pabbly Connect. This guide details step-by-step integration with Google Sheets and more. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To create AI-generated posts in WordPress, you first need to access Pabbly Connect. This platform facilitates the integration process between various applications like Google Sheets and WordPress. Start by visiting the Pabbly Connect website and signing into your account. If you are a new user, you can sign up for free and receive 100 tasks every month.
After logging in, you will see the dashboard. Click on the ‘Access Now’ button for Pabbly Connect. This will take you to the workspace where you can create your workflow. The first step is to create a new workflow for automating the post generation process.
Once you are in Pabbly Connect, the next step is to create a workflow. Click on the top right corner button labeled ‘Create Workflow’. A dialog box will appear asking for the workflow name and folder selection. Name your workflow ‘Create AI Generated Post in WordPress using AI Agent’ and select a folder for organization.
- Click on ‘Create’ to finalize your workflow setup.
- You will see two windows: one for the trigger and one for the action.
In this setup, the trigger will be Google Sheets, as you will capture post titles and keywords from there. The action will be WordPress, where the generated content will be posted automatically. This integration is made seamless through Pabbly Connect.
3. Setting Up Google Sheets as Trigger
For the trigger application, select Google Sheets and choose the event ‘New or Updated Spreadsheet Row’. Pabbly Connect will provide you with a webhook URL to connect Google Sheets to the workflow. Copy this URL as you will need it to set up the Google Sheets add-on.
Open your Google Sheets, navigate to ‘Extensions’, and select ‘Add-ons’. Search for the ‘Pabbly Connect Webhooks’ add-on and install it. After installation, refresh your spreadsheet and go back to ‘Extensions’ to find ‘Pabbly Connect Webhooks’. Click on ‘Initial Setup’ and paste the webhook URL you copied earlier. Set the trigger column to the one containing your keywords and submit the setup.
4. Generating Content Using AI Agent
After setting up the trigger, the next step is to generate the post content using an AI agent. In Pabbly Connect, select OpenAI as your action application and choose the event ‘ChatGPT’. You will need to connect to OpenAI by entering your API token. If you don’t have one, you can generate it from your OpenAI account.
Once connected, specify the AI model, such as GPT-4 Mini, and create a prompt that instructs the AI on the type of content to generate. Map the post title and keywords from the previous step to ensure the AI generates relevant content based on your input. Click on ‘Save and Send Test Request’ to generate the content, which will be returned in HTML format.
5. Posting the Generated Content to WordPress
Now that you have the content generated, it’s time to post it to WordPress. In Pabbly Connect, select WordPress as the action application and choose ‘Create New Post’ as the event. Connect to your WordPress account by entering your username, password, and base URL.
Map the title and content fields with the data received from the AI agent. Set the post status to ‘Draft’ if you want to review it before publishing. After filling in all required fields, click on ‘Save and Send Test Request’. This will create a new post in your WordPress account, allowing you to check the generated content.
In this tutorial, we explored how to create AI-generated posts in WordPress using Pabbly Connect. By integrating Google Sheets and OpenAI, you can automate the content creation process, saving time and enhancing engagement. With Pabbly Connect, managing your content workflow becomes efficient and straightforward.
