Learn how to automate the process of creating ActiveCampaign contacts using Typebot and Pabbly Connect with this detailed tutorial. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
1. Setting Up Pabbly Connect for Typebot Integration
To start the integration between Typebot and ActiveCampaign, you first need to set up Pabbly Connect. This powerful automation tool allows you to connect various applications seamlessly. Begin by signing up for a free Pabbly Connect account, which can be done in just a few minutes.
Once you have created your account, log into the Pabbly Connect dashboard. From here, you will create a new workflow to facilitate the integration. Click on the ‘Create Workflow’ button and name your workflow, for instance, ‘Typebot to ActiveCampaign’. After selecting a suitable folder, click on ‘Create’. This will take you to a new workflow screen where you can set up your automation.
2. Configuring the Trigger Step in Pabbly Connect
The next step is to configure the trigger in your Pabbly Connect workflow. This trigger will activate whenever a user interacts with your Typebot and submits their details. In the trigger window, search for and select ‘Typebot’ as the application. using Pabbly Connect
- Select the event as ‘Block Triggered’ from the dropdown menu.
- Pabbly Connect will generate a webhook URL for you.
- Copy this webhook URL to integrate it into your Typebot flow.
After copying the webhook URL, navigate to your Typebot flow. Add a new step at the end of your flow and paste the webhook URL into the designated area. This integration allows Pabbly Connect to receive data from Typebot whenever a user submits their information.
3. Capturing User Data from Typebot
Once the webhook is set up, you need to capture the user’s data. After users interact with your Typebot and provide their details, Pabbly Connect will receive this information through the webhook. This process happens in real-time, ensuring that the data is transferred instantly. using Pabbly Connect
To test this setup, initiate a conversation with your Typebot. Enter the required details such as name, email, and phone number. After submission, you will see the captured data reflected in Pabbly Connect. This confirms that your Typebot is successfully sending data to Pabbly Connect.
4. Configuring the Action Step to Create ActiveCampaign Contact
With the trigger set, the next step is to configure the action that will take place in ActiveCampaign. In the action window of your Pabbly Connect workflow, search for and select ‘ActiveCampaign’. Choose the action event as ‘Create or Update Contact’. using Pabbly Connect
- Connect your ActiveCampaign account to Pabbly Connect by entering your API key and URL.
- Map the fields from the Typebot responses to the corresponding fields in ActiveCampaign.
- Ensure to split the full name into first and last names if necessary.
After mapping all the necessary fields, click on ‘Save and Send Test Request’. This action will send the user data to ActiveCampaign, creating a new contact based on the information gathered from Typebot.
To ensure everything is working as expected, conduct a test of your entire integration. Go back to your Typebot and initiate a new conversation, entering different user details. This will trigger the workflow in Pabbly Connect once again.
After submission, check your ActiveCampaign account to verify that the new contact has been created with the details you entered. The automation should function seamlessly, demonstrating the power of Pabbly Connect in integrating Typebot and ActiveCampaign.
With this setup, you can automate the process of adding contacts from Typebot to ActiveCampaign, streamlining your workflow and saving time. You can also explore other integrations using Pabbly Connect for even more automation possibilities.
In this tutorial, we explored how to create ActiveCampaign contacts using Typebot and Pabbly Connect. By following these steps, you can automate data transfer between applications effectively, enhancing your workflow efficiency.
