Learn how to create a Telegram bot for free using Pabbly Connect in this detailed step-by-step tutorial. Integrate Telegram with Open AI seamlessly! Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
1. Accessing Pabbly Connect for Telegram Bot Integration
To create a Telegram bot using Pabbly Connect, start by opening a new browser tab. Search for Pabbly Connect at pabbl.com/connect. This will take you to the landing page where you can either sign in or sign up for a free account.
If you are a new user, click on ‘Sign Up for Free’ to get 100 free tasks per month. Existing users can simply sign in. Once logged in, navigate to Pabbly Connect and click on the access button to start creating your workflow.
After accessing Pabbly Connect, click on ‘Create Workflow’. You will be prompted to select the workflow builder. Choose the new workflow builder and enter a name for your workflow. Optionally, select a folder to save your workflow.
  • Enter the workflow name.
  • Choose a folder or create a new one.
  • Click on ‘Create’ to open the workflow window.
In this window, you will set up triggers and actions, which are essential for automating your Telegram bot. The trigger initiates the workflow, while actions define the results.
3. Setting Up the Trigger with Telegram Bot
To begin, click on the ‘Add Trigger’ button. Search for ‘Telegram’ and select ‘Telegram Bot’. For the event, choose ‘Set Webhook/Watch Updates’ and click ‘Connect’. If you have an existing connection, select it; otherwise, create a new one.
To create a new connection, you will need a token from Telegram. Open your Telegram account and search for ‘BotFather’. Start a chat and use the command ‘/newbot’ to create a new bot. Follow the prompts to name your bot and set a username with ‘_bot’ at the end. Once created, copy the token provided and paste it into Pabbly Connect.
4. Generating Images Using Open AI
After setting up the trigger, the next step is to generate images using Open AI. Click on ‘Add New Action Step’ and search for ‘Open AI’. Select ‘Generate Image’ as the event and click ‘Connect’. If you need to create a new connection, enter your Open AI API key. using Pabbly Connect
  • Select ‘Generate Image’ as the action event.
  • Map the message text from the Telegram trigger as the prompt.
  • Specify image size and quality settings.
Once everything is set up, click ‘Save and Send Test Request’. This will generate the image based on the prompt you provided in Telegram.
5. Sending the Generated Image Back to Telegram
After generating the image, the final step is to send it back to your Telegram group. Click on ‘Add New Action Step’ and search for ‘Telegram Bot’. Select ‘Send a Photo’ as the event and connect using the same connection.
To get the chat ID for your group, open your Telegram account in a web browser and ensure you are in the A version. Copy the number after the hashtag in the URL and paste it into Pabbly Connect. You can also add a caption if desired. Finally, click ‘Save and Send Test Request’ to send the image back to the group.
In this tutorial, we explored how to create a Telegram bot using Pabbly Connect to integrate with Open AI. By following these steps, you can automate image generation based on messages sent in your Telegram group. Enjoy the seamless integration provided by Pabbly Connect to enhance your business processes!
