Learn how to automate the process of adding Mailgun members when a purchase is made on FlexiFunnels using Pabbly Connect. Step-by-step tutorial included. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
1. Setting Up Pabbly Connect for FlexiFunnels and Mailgun Integration
To create a Mailgun member upon a purchase in FlexiFunnels, you first need to set up Pabbly Connect. Start by accessing the Pabbly Connect website and signing in to your account. If you’re new, simply sign up for a free account to explore its features.
Once logged in, navigate to the dashboard where you will find various Pabbly applications. Click on Pabbly Connect to initiate the integration process. Here, you can create a new workflow to connect FlexiFunnels with Mailgun.
To begin the workflow, click on the Create Workflow button. Name your workflow something descriptive like ‘Create Mailgun Member on FlexiFunnels Purchase.’ Choose the folder where you want to save this workflow, for instance, the ‘Automations’ folder.
- Click on the Create button.
- Select FlexiFunnels as your trigger application.
- Choose the trigger event as New Purchase.
After setting the trigger, Pabbly Connect will provide you with a webhook URL. This URL will be used in FlexiFunnels to initiate the connection. Copy this URL as it will be needed for the next steps.
3. Configuring FlexiFunnels to Trigger Pabbly Connect
Now, log in to your FlexiFunnels account. Navigate to the product settings where you want to set the rules for purchases. Click on Edit for the specific product, such as ‘Programming in Python.’ Then go to the Set Rules section.
- Select Product is Purchased for all pricing options.
- Choose the option to use a webhook.
- Paste the copied webhook URL into the Endpoint URL field.
Save your changes in FlexiFunnels. This configuration will ensure that every time a purchase is made, it triggers the webhook and sends the necessary data to Pabbly Connect.
4. Testing the Integration with a Purchase
After setting up the webhook, you need to test the integration. Go back to FlexiFunnels and make a test purchase. Enter a name like ‘Demo User’ and complete the order. Once the purchase is successful, Pabbly Connect will capture the webhook response.
Check the Pabbly Connect dashboard to see if the test submission has been recorded. You should see all the details you entered, including the first name, last name, and email address. This confirms that the integration is working correctly.
5. Adding Mailgun Member through Pabbly Connect
Now that the test submission is successful, it’s time to set up Mailgun as the action application in Pabbly Connect. Select Mailgun and choose the action event as New Mailing List Member.
You will need to connect your Mailgun account by entering the API key and domain name. This information can be found in your Mailgun account settings. Once connected, map the email address and name fields from the previous step to add the new member.
Click on Save and Send Test Request to finalize the process. You should receive a confirmation that the member has been added successfully. Check your Mailgun account to see if the new member appears in your list.
This tutorial demonstrated how to automate the process of adding a Mailgun member whenever a purchase is made on FlexiFunnels using Pabbly Connect. By following these steps, you can streamline your email marketing efforts and ensure all customers are added to your mailing list instantly.
