Learn how to automate LinkedIn posts using Google Suggested Keywords with Pabbly Connect in this detailed step-by-step tutorial. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To start automating LinkedIn posts using Google Suggested Keywords, you need to access Pabbly Connect. Open your browser and navigate to Pabbly.com/connect. This platform will serve as the central hub for integrating your applications.
Once on the Pabbly Connect landing page, you will see options for signing in or signing up. If you already have an account, click on ‘Sign In’. If you are new, select ‘Sign Up for Free’ to create an account, which only takes two minutes. After signing in, you will land on the dashboard where you can manage your workflows.
Now that you are on the dashboard of Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button. A dialog box will prompt you to name your workflow, so enter ‘Create LinkedIn AI Agent to Automate LinkedIn Post Using Google Suggested Keyword’.
- Provide a name for your workflow.
- Select a folder to save this workflow.
- Click on ‘Create’ to finalize the workflow setup.
Once created, the screen will display two main windows: Trigger and Action. The Trigger is the event that starts the workflow, while the Action is what happens in response. In this case, the Trigger will be a new row in Google Sheets, and the Action will be to generate a post using an AI agent.
3. Setting Up the Trigger with Google Sheets
To set up the Trigger in Pabbly Connect, select Google Sheets as the application. The Trigger event you need to choose is ‘New or Updated Spreadsheet Row’. This means that whenever a new row is added to your Google Sheets, the workflow will activate.
After selecting the Trigger event, Pabbly Connect will provide a webhook URL. Copy this URL, as it will be used to connect Google Sheets to Pabbly Connect. Next, go to your Google Sheets, click on Extensions, then Add-ons, and select ‘Get Add-ons’. Search for the Pabbly Connect Webhooks add-on and install it.
- Install the Pabbly Connect Webhooks add-on.
- Enter the webhook URL in the add-on settings.
- Select the trigger column for your data.
After setting this up, every time a new row is added in Google Sheets, the data will automatically be sent to Pabbly Connect for processing.
4. Generating LinkedIn Post Content with AI
With the Trigger set up, the next step in Pabbly Connect is to generate the content for your LinkedIn post using an AI agent. Select OpenAI as the action application and choose the action event ‘ChatGPT’. This will allow you to generate content based on the keywords from your Google Sheets.
To establish a connection between OpenAI and Pabbly Connect, you need to provide the API key from your OpenAI account. Once connected, select the AI model you want to use, such as GPT-4. Then, create a prompt for the AI that instructs it to write a LinkedIn post using the keyword from the Google Sheets.
Select the AI model (e.g., GPT-4). Create a prompt for the AI to generate content. Map the keyword dynamically from the previous step.
This dynamic mapping ensures that the AI generates a relevant post every time a new keyword is added to Google Sheets, automating your LinkedIn content creation.
5. Posting the Generated Content to LinkedIn
After generating the content, the final step in Pabbly Connect is to post the content on LinkedIn. Select LinkedIn as the action application and choose the action event ‘Share Simple Text’. This allows you to share the generated content directly to your LinkedIn profile.
Once again, you need to connect your LinkedIn account with Pabbly Connect. After successful connection, you will be prompted to map the content generated from the AI step. Decide whether you want the post to be Pabbly or limited to connections before finalizing the action.
Map the content generated from OpenAI. Select visibility options for the post. Click on ‘Save and Send Test Request’ to finalize.
Once completed, you will receive a response indicating that the post has been successfully created on your LinkedIn profile. This automation ensures that every time a new keyword is added to Google Sheets, a corresponding post is automatically generated and shared on LinkedIn.
In this tutorial, we explored how to automate LinkedIn posts using Google Suggested Keywords with Pabbly Connect. By following the steps outlined, you can streamline your content creation process, ensuring consistent engagement on your LinkedIn profile. Automate your LinkedIn posting today with Pabbly Connect and enhance your marketing efforts effortlessly!
