Learn how to create blogs from audio files using Pabbly Connect. This tutorial covers step-by-step integration with Google Drive, OpenAI, and Google Docs. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To create a blog from audio files, you first need to access Pabbly Connect. This platform enables seamless integration between various applications required for this process.
Begin by navigating to your web browser and searching for Pabbly Connect. You will see options to either sign in or sign up. If you are new, click on ‘Sign Up Free’ to create an account, or if you already have an account, simply sign in.
Once logged into Pabbly Connect, you will need to create a workflow. Click on the ‘Create Workflow’ button and name your workflow, for example, ‘AI Agent for Blog Creation from Audio Files’. Select your folder for organization and hit ‘Create’.
In your workflow, you will see two main windows: the trigger window and the action window. The trigger window is where you will set up the event that starts the automation. The action window will define what happens after the trigger event.
- Select the appropriate folder for your workflow.
After creating your workflow, you are ready to set up the trigger event that will activate the AI agent.
3. Setting Up Google Drive in Pabbly Connect
In this step, you will connect your Google Drive account to Pabbly Connect. This connection allows the AI agent to access audio files uploaded to a designated folder. In the trigger step, search for Google Drive and select it.
Choose the trigger event as ‘New File in Specific Folder’. Click on connect, then select ‘Add New Connection’. Sign in to your Google account and allow access.
- Select Google Drive as the app.
- Choose ‘New File in Specific Folder’ as the trigger event.
- Connect your Google Drive account.
After setting up the Google Drive connection, you need to ensure the audio files have the correct sharing permissions for the AI agent to access them.
4. Transcribing Audio Files Using OpenAI
After successfully connecting your Google Drive, the next step involves sending the audio file to OpenAI for transcription. In the action step of Pabbly Connect, search for OpenAI and select it.
Choose the action event as ‘Generate Transcript’. Connect your OpenAI account by entering your API key, which you can obtain from your OpenAI dashboard. Once connected, map the audio file URL received from Google Drive to the audio file URL field in OpenAI.
Select OpenAI as the action app. Choose ‘Generate Transcript’ as the action event. Map the audio file URL from Google Drive.
Once you have mapped the audio file URL, click on ‘Save and Send Test Request’ to receive the transcription response from OpenAI.
5. Creating Blog Content and Saving to Google Docs
After receiving the transcription, the next step is to generate blog content using the transcription data. In this step, you will add another action in Pabbly Connect to send the transcription to OpenAI again using ChatGPT.
Search for OpenAI again and select the action event as ‘ChatGPT Structured Output’. Connect using the existing connection. Here, you will enter the prompts for the AI to generate the blog title, content, and keywords. Ensure to select the JSON schema response format to receive structured data.
Use ‘ChatGPT Structured Output’ for generating content. Enter prompts for title, content, and keywords. Select JSON schema for structured output.
Finally, connect Google Docs to create a new document using the generated blog content and save it in your designated folder.
In this tutorial, you learned how to create a blog from audio files using Pabbly Connect. By integrating Google Drive, OpenAI, and Google Docs, you can automate blog creation efficiently. This process allows you to focus on content creation while the AI handles transcription and formatting.
