Learn how to convert leads into customers using Elementor and WhatsApp through Pabbly Connect in this detailed tutorial. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
1. Setting Up Pabbly Connect for Elementor and WhatsApp Integration
To convert leads into customers using Elementor and WhatsApp, first, you need to set up Pabbly Connect. Start by visiting Pabbly.com/connect and sign up for a free account. After signing in, you will be directed to the Pabbly Connect dashboard where you can create your first workflow.
Click on the ‘Create Workflow’ button. Name your workflow something descriptive, like ‘Convert Elementor Form Leads Using WhatsApp’. This naming will help you easily identify the workflow later. After naming, proceed by clicking on the ‘Create’ button to access the workflow page.
2. Choosing Elementor as the Trigger Application in Pabbly Connect
Within the workflow page of Pabbly Connect, you will need to set a trigger for your automation. For this integration, select Elementor as your trigger application. The trigger event will be ‘New Form Submission’, which captures leads generated via your Elementor forms.
Once selected, Pabbly Connect will provide you with a webhook URL. This URL is crucial as it connects Elementor to Pabbly Connect. Copy this webhook URL and head over to your Elementor editor to integrate it into your lead generation form.
- Open the Elementor editor for your form.
- Navigate to ‘Actions After Submit’ and add a new action called ‘Webhook’.
- Paste the copied webhook URL into the webhook field.
After completing these steps, click on the ‘Update’ button to save your changes in Elementor. Your form is now set up to send data to Pabbly Connect whenever a new lead submits their information.
3. Testing the Integration with Pabbly Connect and Elementor
With your Elementor form connected to Pabbly Connect, it’s time to test the integration. Go back to your form’s Pabbly view and fill out a test submission with sample data. Ensure you include all necessary fields, such as name, email, and WhatsApp number.
After submitting the form, return to your Pabbly Connect workflow. You should see the test submission data captured in the ‘Response Received’ section. This confirms that your Elementor form is successfully communicating with Pabbly Connect.
- Check for the captured data including name, email, and WhatsApp number.
- If data appears correctly, proceed to the next step of sending WhatsApp messages.
Now that your test submission is successful, you are ready to set up the action step that sends a WhatsApp message to your leads.
To send a WhatsApp message through Pabbly Connect, you will need to choose WhatsApp Cloud API as your action application. Select the action event ‘Send Template Message’ to configure the message that will be sent to your leads.
Before you can send messages, ensure you have access to WhatsApp’s Cloud API. After connecting your WhatsApp number to the API, return to Pabbly Connect and configure the connection settings. You will need to provide your token, phone number ID, and business account ID.
Select ‘Add New Connection’ to input your WhatsApp Cloud API credentials. Map the recipient’s WhatsApp number from the previous step. Attach your business brochure as a document in the message.
Once all settings are configured, click on ‘Save and Send Test Request’ to check if the WhatsApp message is sent successfully. You should see the message appear in your WhatsApp as a confirmation that the integration works smoothly.
5. Conclusion: Automate Your Lead Conversions with Pabbly Connect
In this tutorial, we demonstrated how to convert leads for your business using Elementor and WhatsApp with the help of Pabbly Connect. By setting up this integration, you can automate the process of sending personalized messages to your leads, thereby enhancing your customer conversion rate.
With Pabbly Connect, you can streamline your lead generation and follow-up process without any coding skills. This powerful automation tool simplifies the connection between your Elementor forms and WhatsApp, allowing you to focus on growing your business.
Now that you have learned how to set up this automation, you can implement it for your own business and enjoy the benefits of increased efficiency and productivity.
