Learn how to connect unlimited WhatsApp numbers in a single account with Pabbly Connect and Pabbly Connect without any extra cost. Follow our detailed tutorial!
1. Introduction to Pabbly Connect and WhatsApp Integration
Pabbly Connect is an automation platform that enables users to connect unlimited WhatsApp numbers seamlessly. This feature allows businesses to manage multiple WhatsApp accounts from a single Pabbly Chatflow account without incurring additional costs. In this tutorial, we will explore how to set up and connect these accounts effectively. using Pabbly Connect
To begin, ensure that you have a Pabbly Connect account and have set up your WhatsApp Cloud API accounts. With Pabbly Connect, you can easily integrate these accounts and manage them from one place. This integration is particularly beneficial for businesses that require multiple WhatsApp accounts for different purposes.
2. Setting Up Your WhatsApp Cloud API Account
Before connecting your WhatsApp numbers, you must set up your WhatsApp Cloud API account. This step is crucial as it provides the necessary credentials for integration with Pabbly Connect. Ensure you have the permanent access token, phone number ID, and WhatsApp business account ID ready.
- Create your WhatsApp Cloud API account.
- Obtain your permanent access token, phone number ID, and WhatsApp business account ID.
- Log in to your Pabbly Connect account.
Once you have these details, you can proceed to connect your WhatsApp Cloud API account with Pabbly Connect by following the steps outlined in the next section.
3. Connecting WhatsApp Numbers in Pabbly Connect
To connect your WhatsApp numbers, navigate to the Pabbly Chatflow dashboard. Click on the ‘Add WhatsApp Number’ button to initiate the connection process. You will be prompted to enter your WhatsApp Cloud API credentials, which include the permanent access token, phone number ID, and WhatsApp business account ID. using Pabbly Connect
After entering the required information, select the folder in your Pabbly Chatflow account where you want to connect this WhatsApp number. Click on ‘Next’ to receive the webhook callback URL and webhook token that you will need to configure in your WhatsApp Cloud API account.
4. Configuring Webhook in WhatsApp Cloud API
After receiving the callback URL and webhook token from Pabbly Connect, you need to configure these in your WhatsApp Cloud API account. Go to the configuration section of your WhatsApp Cloud API account and paste the callback URL into the designated field.
- Paste the callback URL in the callback URL field.
- Enter the webhook token in the verify token field.
- Click on the ‘Verify and Save’ button.
Once you have saved these settings, your WhatsApp number will be successfully connected to Pabbly Connect. You can now manage your WhatsApp messages and updates through your Pabbly Chatflow account.
5. Managing Multiple WhatsApp Accounts
After connecting your WhatsApp accounts, you can easily manage them from your Pabbly Chatflow dashboard. If you have multiple WhatsApp numbers connected, you can access the inbox of any specific account by clicking on the ‘Access Inbox’ button next to the respective account.
This feature allows you to handle customer interactions efficiently from a single platform. With Pabbly Connect, you can monitor all your WhatsApp accounts, ensuring that no messages go unanswered and that customer engagement remains high.
In conclusion, using Pabbly Connect to connect unlimited WhatsApp numbers in a single account is a cost-effective solution for businesses. By following the steps outlined in this tutorial, you can easily integrate multiple WhatsApp accounts and manage them efficiently. This integration enhances customer communication and streamlines your business operations.
