Learn how to connect Shopify V2 with Pabbly Connect through this complete setup guide. Automate your store workflows effortlessly! Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
1. Getting Started with Pabbly Connect
To connect Shopify V2 using Pabbly Connect, first access the platform. If you’re a new user, visit pabbl.com/connect in your browser. This will lead you to the Pabbly Connect landing page where you can sign up for free.
Once signed up, you will receive 100 free tasks monthly to explore Pabbly Connect. This allows you to test the integration with Shopify and see how it automates your store workflows.
After logging into Pabbly Connect, navigate to the workflow builder. Here, you will set up a trigger and action that will define how Shopify V2 interacts with other applications.
- Click on ‘Add New Action Step’.
- Search for ‘Shopify V2’ and select it.
- Choose the action event you want, such as ‘Create Customer’.
Once selected, click on ‘Connect’. You will then be prompted to create a new connection by entering your Shopify store’s subdomain, client ID, and client secret.
3. Setting Up the Shopify App
To retrieve the necessary credentials for Pabbly Connect, open your Shopify store and go to Settings. From there, navigate to Apps and select the option to build and manage apps in your dashboard.
Click on ‘Create App’ and name it according to your preference, such as ‘Testing V2’. After creating the app, enter the app URL as https://connect.Pabbly.com and set the required permissions for the app.
- Select all necessary scopes based on your intended actions.
- Click ‘Done’ to save your settings.
Next, copy the redirect URL from the documentation and paste it into the appropriate field in your Shopify app settings. Finally, click on ‘Release’ to finalize the app setup.
4. Installing the Shopify App
Once the app is set up, return to Pabbly Connect to input your client ID and client secret. After entering these details, go back to your Shopify app and click on ‘Install App’.
Select the store where you want to install the app and confirm the permissions required by the app. Once you approve, the app will be installed in your Shopify store, allowing Pabbly Connect to facilitate the integration.
5. Finalizing the Connection
To complete the connection between Shopify V2 and Pabbly Connect, retrieve your store’s subdomain from the general settings in Shopify. Paste this subdomain back into the connection settings in Pabbly.
Click ‘Save’ to finalize the integration. Now, you can use Pabbly Connect to create customers, update customer information, or manage products directly from your Shopify store.
In this guide, we detailed how to connect Shopify V2 with Pabbly Connect, enabling you to automate various store workflows. Utilizing Pabbly Connect simplifies the process, allowing seamless integration and management of your Shopify store.
