Learn how to seamlessly connect LinkedIn to WhatsApp using Pabbly Connect with our step-by-step guide. Automate your lead notifications today! Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To connect LinkedIn to WhatsApp using Pabbly Connect, start by navigating to the Pabbly website. Open a new tab and search for Pabbly.com/connect. This platform is an all-in-one automation tool designed to help you integrate multiple applications without any coding.
Once on the Pabbly Connect page, you will see options to sign in or sign up for free. If you are new to Pabbly Connect, click on ‘Sign Up Free’ to create an account and receive 100 free tasks every month. Existing users should click on ‘Sign In’ to access their dashboard.
After signing in to Pabbly Connect, you will be directed to the dashboard. Here, click on the ‘Access Now’ button under Pabbly Connect to create a new workflow. This step is crucial as it allows you to manage your automation processes effectively.
  • Choose the ‘New Beta’ version for the workflow builder.
  • Name your workflow as ‘Connect LinkedIn to WhatsApp using Pabbly Connect’.
Once you have named your workflow, select a folder for organization and click on the ‘Create’ button. Your workflow setup is now ready to proceed with the trigger application.
3. Setting Up LinkedIn as the Trigger Application
The next step in using Pabbly Connect is to set LinkedIn as the trigger application. This means that whenever a lead applies through your LinkedIn ads, it will automatically send an alert to WhatsApp. Select LinkedIn from the application list and choose the ‘Lead Notifications’ event.
After selecting LinkedIn, click on the ‘Connect’ button. You will have the option to add a new connection or select an existing one. For this tutorial, choose ‘Add New Connection’ and authenticate your LinkedIn account. Once connected, select your LinkedIn ads account and response format as ‘Simple’ before saving the configuration.
4. Configuring WhatsApp as the Action Application
In this step, you will configure WhatsApp as the action application in Pabbly Connect. Click on the plus icon to add a new action and select Pabbly Chatflow as the application. Choose the ‘Send Text Message’ event and click on the ‘Connect’ button.
  • Select ‘Add New Connection’ and enter your API token from Pabbly Chatflow.
  • Map the recipient’s mobile number with the dynamic data received from LinkedIn.
  • Customize your WhatsApp message using the mapped data.
After completing the message setup, click on the ‘Save and Send Test Request’ button to verify the integration. Ensure that the mobile number includes the country code without the plus sign for successful delivery.
5. Finalizing Your Workflow in Pabbly Connect
Once your WhatsApp message has been successfully sent, you have completed the integration process using Pabbly Connect. Make sure to enable the toggle switch to activate your workflow. If this toggle is not enabled, your automation will not function properly.
This setup ensures that every time a new lead applies through your LinkedIn ad, they will receive an instant WhatsApp alert with their details. If you encounter any issues during the setup, feel free to reach out for support or check the comments section for assistance.
In this tutorial, we explored how to connect LinkedIn to WhatsApp using Pabbly Connect. Automating your lead notifications can save time and enhance communication with potential clients. Start using this powerful automation tool today!
