To start integrating WhatsApp with Pabbly Connect, first, you need to access the Pabbly Connect platform. Go to the Pabbly Connect website and either sign in or create a free account.
Once you’re on the homepage, click on the ‘Sign Up Free’ button if you’re a new user. Existing users can simply log in. Pabbly Connect offers a free plan with 100 tasks per month, allowing you to explore its features.
After accessing Pabbly Connect, the next step is to create a workflow that connects WhatsApp and Facebook. Click on the ‘Create Workflow’ button to start.
- Select ‘Create from Scratch’.
- Choose the AI method for workflow creation.
Once your workflow is set up, you will be prompted to configure the trigger event. This event will initiate the automation process whenever a new lead is captured from Facebook.
3. Setting Up the Trigger for Facebook Leads
In this section, you will set up the trigger to capture new leads from Facebook. Choose ‘Facebook Lead Ads’ as your application and select ‘New Lead’ as the trigger event.
Next, you will need to connect your Facebook account to Pabbly Connect. This can be done by clicking on ‘Add New Connection’ and following the prompts to authorize Pabbly Connect to access your Facebook account.
- Select the specific Facebook page.
- Choose the lead generation form you want to use.
- Click ‘Continue’ to save your settings.
Once you’ve set up the trigger, it’s essential to test it to ensure that Pabbly Connect can successfully capture leads from Facebook. This test will help confirm that your integration is functioning properly.
4. Sending WhatsApp Messages through Pabbly Connect
Now that your trigger is set up, you can configure the action to send a WhatsApp message using Pabbly Chatflow. Select ‘Pabbly Chatflow’ as your application and choose ‘Send Message’ as the action event.
To send a personalized message, you will need to input the WhatsApp number of the lead. Instead of entering the number manually, map the phone number field from the Facebook lead data you captured earlier.
- Compose your message, including any special discount codes.
- Use dynamic fields to personalize the message.
- Click ‘Save and Send Request’ to finalize the setup.
With this setup, every time a new lead is captured from Facebook, a personalized WhatsApp message will be sent automatically, enhancing customer engagement.
After setting up the WhatsApp messaging action, it’s crucial to test your entire workflow to ensure everything is functioning as intended. You can do this by generating a test lead through your Facebook lead form.
Once the test lead is submitted, check your WhatsApp to see if the personalized message was received. This verification step confirms that Pabbly Connect has successfully integrated WhatsApp with Facebook.
- Make sure the message content is accurate and personalized.
- Ensure that the lead’s phone number is correctly mapped.
- Make adjustments if needed and retest.
Once verified, you can confidently use this automation to convert leads into paying customers effectively.
In this tutorial, we explored how to integrate WhatsApp with Pabbly Connect to streamline communication with leads. By following these steps, you can automate sending personalized messages, enhancing customer engagement and conversion rates.
