Learn how to automate podcast blog publishing with Pabbly Connect by integrating Google Drive, AI Agent, and WordPress in this detailed tutorial. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To start building an AI agent to auto publish podcast blogs, first access Pabbly Connect. Open your browser and navigate to Pabbly.com/connect. Here, you’ll find options to sign in or sign up for free.
If you’re a new user, click on ‘Sign up for free’ to explore the application with 100 tasks free every month. For existing users, click ‘Sign in’ to access your dashboard where all Pabbly applications are listed.
After signing in to Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button, and name your workflow ‘How to Build an AI Agent to Auto Publish Podcast Blogs’. Choose the folder where you want to save this workflow.
Once your workflow is created, you will see the workflow window where you can set up triggers and actions. Triggers are events that start your workflow, while actions are the tasks that follow. In this case, we will set Google Drive as the trigger application.
3. Setting Up Google Drive as a Trigger
In the workflow window, select Google Drive as your trigger application and choose the trigger event ‘New File in a Specific Folder’. Click on the ‘Connect’ button to link your Google Drive account with Pabbly Connect.
You will need to sign in with your Google account and grant necessary permissions. After connecting, select the specific folder named ‘podcast’ where your audio files will be uploaded. Ensure this folder is shareable so that the AI agent can access the files.
  • Select Google Drive as the trigger application.
  • Choose the trigger event ‘New File in a Specific Folder’.
  • Connect your Google Drive account.
  • Select the ‘podcast’ folder as the target.
After saving these settings, your workflow will be ready to trigger whenever a new podcast file is added to the specified folder.
4. Transcribing Audio with AI Agent
Next, we need to transcribe the audio file using the AI agent. Select OpenAI as your action application and choose the action event ‘Generate Transcript (Whisper)’. Click on ‘Connect’ and enter your OpenAI API key to establish the connection with Pabbly Connect.
Once connected, map the audio file URL from the previous Google Drive trigger. This mapping allows the AI agent to dynamically access the audio file for transcription. After mapping, click on the ‘Save and Send Test Request’ button to generate the transcript.
  • Select OpenAI as the action application.
  • Choose ‘Generate Transcript (Whisper)’ as the action event.
  • Map the audio file URL from Google Drive.
  • Click ‘Save and Send Test Request’ to generate the transcript.
After successfully generating the transcript, you can move on to the next step to create the blog content.
5. Generating Blog Content and Publishing
To create the blog post, add another action step in your workflow and select OpenAI again. This time, choose ‘Structured AI Output (ChatGPT)’ as the action event. Connect to OpenAI using the previously established connection in Pabbly Connect.
Now, you need to map the transcript generated in the previous step as input for the AI agent. Enter a prompt like ‘Write a detailed and engaging blog post based on the transcription of the podcast episode’. Also, define the response format to include both the blog title and content. Finally, click ‘Save and Send Test Request’ to generate the blog post.
After the blog content is generated, add a final action step to publish it on WordPress. Select WordPress as the action application and choose ‘Create a Post’ as the action event. Connect to your WordPress account and map the blog title and content. Set the post status to ‘Publish’ and save the settings. This will automatically publish your blog post on WordPress.
In this tutorial, we explored how to use Pabbly Connect to automate the process of publishing podcast blogs. By integrating Google Drive, an AI agent, and WordPress, you can save time and streamline your content creation process. With Pabbly Connect, the entire workflow runs seamlessly in the background, allowing you to focus on your podcasting without the hassle of manual blogging.
