Learn how to use Pabbly Connect to create an AI agent for auto-generating WordPress travel guides with Google Sheets and OpenAI. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To build an AI agent for auto-generating WordPress travel guides, you first need to access Pabbly Connect. Start by visiting the Pabbly website and signing into your account. If you are a new user, you can sign up for free and receive 100 tasks monthly.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you can create a new workflow by clicking on the ‘Create Workflow’ button. Name your workflow, such as ‘How to Build an AI Agent to Auto-Generate WordPress Travel Guides,’ and select a folder to save it in. This sets the stage for integrating Google Sheets, OpenAI, and WordPress through Pabbly Connect.
2. Setting Up Google Sheets with Pabbly Connect
The next step involves setting up Google Sheets as the trigger application in your Pabbly Connect workflow. You will need to create a Google Sheet with three columns: Topic ID, Title, and Content. The Title field will be used for generating the travel guide.
  • Open your Google Sheet and enter a Topic ID and Title for your travel guide.
  • In Pabbly Connect, select Google Sheets as your trigger application.
  • Choose the trigger event as ‘New or Updated Spreadsheet Row’.
After setting this up, you will receive a webhook URL from Pabbly Connect. This URL will be used to connect your Google Sheets with the workflow. Make sure to copy this URL and proceed to the Google Sheets add-ons to set up the webhook.
3. Configuring the Webhook in Google Sheets
To configure the webhook, go back to your Google Sheets and click on ‘Extensions’, then ‘Add-ons’, and select ‘Get Add-ons’. Search for the Pabbly Connect Webhooks add-on and install it. Once installed, click on ‘Initial Setup’ in the add-on.
  • Paste the webhook URL from Pabbly Connect into the designated field.
  • Set the trigger column to the last column where data will be entered, which is typically the Title column.
After entering these details, click on ‘Send Test’. If successful, you will receive a confirmation that the setup is configured correctly. This step ensures that any new titles added to the Google Sheet will trigger the automation in Pabbly Connect.
4. Generating Travel Guide Content with OpenAI
Now that your Google Sheets is set up, the next step is to use OpenAI to generate the travel guide content. In your Pabbly Connect workflow, add OpenAI as the action application. Choose the action event as ‘Generate Content’.
To connect OpenAI, you will need an API token. If you don’t have one yet, you can create it in your OpenAI account. Once you have the token, enter it in Pabbly Connect. Set the AI model to GPT-4 and create a prompt that instructs OpenAI to generate a travel guide based on the title entered in Google Sheets.
Use a prompt like ‘Write a detailed travel guide for {Title}’ where {Title} is dynamically mapped from Google Sheets. Ensure that the response includes key sections such as introduction, attractions, local foods, and travel tips.
After setting this up, test the action to ensure that OpenAI generates the content correctly. This is a crucial step in your automation process with Pabbly Connect.
5. Posting the Generated Content to WordPress
The final step is to post the generated content to your WordPress site. In your Pabbly Connect workflow, add WordPress as the next action application. Select ‘Create Post’ as your action event.
To connect WordPress, you will need to provide your website’s base URL and login credentials. Once connected, you can map the title and content generated by OpenAI to the appropriate fields in WordPress. Set the post status to ‘Publish’ to automatically publish the travel guide.
Map the title from OpenAI to the WordPress post title field. Map the content generated by OpenAI to the WordPress post content field.
Once everything is set up, click on ‘Save and Send Test’. If successful, you will see the new post appear on your WordPress site. This completes the integration process using Pabbly Connect, allowing you to automate the creation of travel guides effortlessly.
In this tutorial, we demonstrated how to use Pabbly Connect to automate the generation of WordPress travel guides using Google Sheets and OpenAI. By following these steps, you can streamline your content creation process and enhance your online presence as a travel blogger.
