Learn how to automate LinkedIn recruitment posts using Pabbly Connect with Google Sheets and OpenAI. Step-by-step tutorial included. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
1. Accessing Pabbly Connect to Start Automation
To begin automating LinkedIn recruitment posts, first access Pabbly Connect by navigating to Pabbly.com/connect in your browser. This platform will facilitate the integration of Google Sheets, OpenAI, and LinkedIn.
If you’re a new user, click on the ‘Sign up for free’ button to create your account. Existing users can simply sign in. Upon signing up, you will receive 100 free tasks every month to explore the features of Pabbly Connect.
Once logged into Pabbly Connect, you will be directed to the dashboard. Click on the ‘Create Workflow’ button to initiate a new automation process. Name your workflow something descriptive, like ‘Build an AI Agent to Auto-Generate LinkedIn Recruitment Posts’.
After naming your workflow, choose a folder to save it in. For this example, select the ‘AI Automations’ folder. The workflow is now created, and you will see two main sections: Trigger and Action. The Trigger section will define what event starts the automation, while the Action section will specify what happens when that event occurs.
3. Setting Up Google Sheets as the Trigger
In the Trigger section, select Google Sheets as your application. The trigger event you want is ‘New or Updated Spreadsheet Row’. This means that every time a new row is added to your Google Sheets, the automation will be triggered.
To connect Google Sheets to Pabbly Connect, you will receive a webhook URL. Copy this URL and go to your Google Sheets. Navigate to Extensions > Add-ons > Get Add-ons and search for ‘Pabbly Connect Webhooks’ to install the necessary add-on.
- Install the Pabbly Connect Webhooks add-on.
- Paste the webhook URL in the add-on settings.
- Set the trigger column as the last column containing data.
After configuring these settings, send a test request from Google Sheets to ensure the connection with Pabbly Connect is successful.
4. Generating Content Using OpenAI
Now that your Google Sheets is set up, it’s time to generate the LinkedIn post content using OpenAI as your AI agent. In the Action section of Pabbly Connect, select OpenAI and choose the action event ‘ChatGPT’ to create content.
To establish a connection between OpenAI and Pabbly Connect, you need to input your OpenAI API key. Click on the provided link to generate a new secret key from OpenAI, then paste it back into Pabbly Connect.
- Select the model (e.g., GPT-4) for content generation.
- Create a prompt that instructs OpenAI on the content requirements.
- Map the required fields from the Google Sheets response to the prompt.
This setup ensures that each time a new row is added, OpenAI will generate a LinkedIn post tailored to the job details provided in your Google Sheets.
5. Posting the Generated Content on LinkedIn
With the content generated, the final step is to share it on LinkedIn. In the Action section of Pabbly Connect, choose LinkedIn and select the action event ‘Share Simple Text’.
Connect your LinkedIn account to Pabbly Connect and specify the author and the content you want to share. Decide on the visibility settings for your post, such as Pabbly or connections only. Once everything is set, click on the ‘Save and Send Test Request’ button to publish the post.
After completing these steps, you will see the post appear on your LinkedIn profile, confirming that the integration between Google Sheets, OpenAI, and LinkedIn via Pabbly Connect is successful. This automation will save you time and keep your LinkedIn updated with minimal effort.
In this tutorial, we explored how to utilize Pabbly Connect to automate the process of generating LinkedIn recruitment posts using Google Sheets and OpenAI. This integration simplifies your workflow, ensuring timely and professional postings with ease.
