Learn to automate Facebook ad generation for product launches using Pabbly Connect, Google Sheets, and AI agents. Step-by-step tutorial included. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
1. Accessing Pabbly Connect for Facebook Ads Automation
To start automating Facebook ads for product launches, first, access Pabbly Connect. This platform serves as the central hub for integrating various applications, including Google Sheets and Facebook.
Visit the Pabbly Connect website and either sign in or create a new account. If you are a new user, you can sign up for free and receive 100 free tasks every month. Once logged in, you will be directed to the Pabbly Connect dashboard, where you can begin creating your workflow.
In this section, you will create a new workflow for your AI agent that generates Facebook ads. Start by clicking on the ‘Create Workflow’ button in the top right corner of the Pabbly Connect dashboard.
When prompted, give your workflow a name, such as ‘AI Agent to Auto-Generate Facebook Ads Product Launches’. Select a folder to save this workflow for easy access later. Follow these steps to set up your workflow:
  • Click on the ‘Create’ button to initiate the workflow.
  • Choose ‘Google Sheets’ as the trigger application.
  • Set the trigger event to ‘New or Updated Spreadsheet Row’.
Once you have set these options, click on the ‘Connect’ button to establish a connection with Google Sheets through Pabbly Connect.
3. Setting Up the Trigger with Google Sheets
After connecting Google Sheets, you need to configure the trigger to capture new product details automatically. This is crucial for generating Facebook ads based on the latest product launches.
In your Google Sheets, ensure that you have a designated column for tracking new product entries. For this workflow, the trigger column will be set to the final data column, which will be updated whenever a new product detail is added. Follow these steps:
  • Paste the provided webhook URL from Pabbly Connect into your Google Sheets add-ons.
  • Select the appropriate column (e.g., Column F) as your trigger column.
  • Submit the configuration to finalize the trigger setup.
Once configured, the trigger will capture any new data entered into the specified column, allowing Pabbly Connect to process this information further for ad generation.
