Learn how to automate publishing WordPress posts on Blogger with Pabbly Connect. Step-by-step tutorial for seamless integration. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To start the integration process, access Pabbly Connect by typing ‘Pabbly.com/connect’ in your browser. This platform is essential for automating the publishing of WordPress posts to Blogger.
Once on the homepage, you will see options to sign in or sign up for free. If you are a new user, click on the ‘Sign Up for Free’ button. Existing users should click on ‘Sign In’. After logging in, navigate to the ‘All Apps’ section to access Pabbly Connect.
In Pabbly Connect, create a new workflow by clicking the ‘Create Workflow’ button. A dialog box will appear asking for a workflow name. Enter ‘Publish WordPress Post on Google Blogger Automatically’ and choose a folder to save your workflow.
- You will see two windows for trigger and action.
For the trigger, select ‘WordPress’ and choose ‘New Post Published’ as your trigger event. This setup ensures that every time a new post is published on WordPress, the automation will trigger the action in Pabbly Connect.
3. Setting Up WordPress for Automation
Copy the provided webhook URL from Pabbly Connect and navigate to your WordPress dashboard. Go to Settings and select ‘WP Webhooks’. Under ‘Send Data’, choose ‘Post Created’ to set up the connection.
- Click on ‘Add Webhook URL’.
- Provide a name for the webhook and paste the copied URL.
- Set trigger options to ‘Post’ and ‘Publish’.
After saving the settings, return to Pabbly Connect where it will show ‘Waiting for Webhook Response’. This indicates that it is ready to receive data from WordPress.
4. Testing the Integration with a New Post
To test the integration, create a new post in WordPress. Go to the Posts section and click on ‘Add New’. Enter a title and content, then publish the post.
Make sure to include an image using the ‘Add Media’ button. After publishing, check back in Pabbly Connect to see if the response is received.
Once the post is published, Pabbly Connect captures the response, allowing you to proceed to the next step of publishing on Blogger.
5. Publishing the Post on Google Blogger
In Pabbly Connect, select ‘Google Blogger’ as the action application and choose ‘Create Post’ as the action event. This step is crucial for transferring the data from WordPress to Blogger.
Connect your Google Blogger account by clicking ‘Sign In with Google’. Authorize Pabbly Connect to access your Blogger account.
Map the fields from the WordPress post to the Blogger post, including the title and content. Choose whether to keep the post live or as a draft. Finally, click on ‘Save and Send Test Request’ to complete the process. Check your Blogger account to confirm that the post has been published successfully.
By following these steps, you can easily automate the process of publishing WordPress posts on Blogger using Pabbly Connect. This integration saves time and ensures that your content reaches a wider audience without manual effort.
