Learn how to automatically post new products to Pinterest from BigCommerce using Pabbly Connect. Step-by-step tutorial for seamless integration. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To begin the process of automatically posting new products to Pinterest from BigCommerce, you first need to access Pabbly Connect. This integration platform simplifies the automation process without any coding skills required.
Start by visiting the Pabbly Connect website by typing pabyt.com in your browser. Once there, sign in to your account. If you’re a new user, you can sign up for free to get started with 100 free tasks monthly. After logging in, navigate to the Pabbly Connect dashboard, where you can create workflows to automate your tasks.
After accessing the dashboard of Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button and select the classic workflow builder for a familiar interface.
- Name your workflow as ‘Automatically Post New Products to Pinterest from BigCommerce’.
- Select a folder for your workflow, such as ‘All Automations’.
- Click on ‘Create’ to finalize your workflow setup.
Once your workflow is created, you will see two boxes: one for the trigger and one for the action. The trigger will be set to BigCommerce, and the action will be set to Pinterest, allowing for seamless integration using Pabbly Connect.
3. Setting Up Trigger and Action for BigCommerce and Pinterest
In this section, you’ll configure the trigger and action for your workflow using Pabbly Connect. Start with the trigger application, selecting BigCommerce as your trigger app.
Choose ‘New Product’ as the trigger event. If you don’t have an existing connection, click on ‘Add New Connection’. You will need to provide your BigCommerce API details, including the Client ID, Access Token, and Store Hash Key. These details can be obtained from your BigCommerce account settings under API accounts.
- Copy the Client ID and Access Token from your BigCommerce API settings.
- Paste these details into the corresponding fields in Pabbly Connect.
- Click ‘Save’ to establish the connection.
After saving the connection, click on ‘Save and Send Test Request’ to capture a response. This response will confirm that your trigger is correctly set up and ready to capture new product details.
4. Creating a Pin in Pinterest Using Pabbly Connect
With the trigger successfully set up, it’s time to create a Pinterest pin automatically when a new product is added in BigCommerce. In this step, use Pabbly Connect to add an action step to your workflow.
Search for Pinterest as your action application and select ‘Create Pin’ as the action event. If you have an existing connection, choose to save it; otherwise, create a new connection by logging into your Pinterest account through Pabbly Connect.
Select the board where you want to post the pin. Map the image URL and product details from the previous steps. Click ‘Save and Send Test Request’ to finalize the action.
After executing this action, check your Pinterest board to confirm that the new pin for the product has been created successfully. This step showcases the power of Pabbly Connect in automating your e-commerce tasks efficiently.
5. Conclusion: Automate Your Product Posting with Pabbly Connect
In this tutorial, we explored how to use Pabbly Connect to automatically post new products from BigCommerce to Pinterest. By following the steps outlined, you can streamline your e-commerce operations effectively.
Utilizing Pabbly Connect not only saves time but also ensures that your product updates are reflected in real-time across platforms. Start automating your workflows today to enhance productivity and efficiency in your online business.
