Learn how to automatically post from your Facebook page to LinkedIn using Pabbly Connect. Streamline your social media management effortlessly! Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To automatically post from Facebook Page to LinkedIn, start by accessing Pabbly Connect. This powerful automation platform allows you to streamline your social media management effectively.
Visit the Pabbly Connect website and sign in to your account. If you are a new user, you can sign up for free and get access to 100 free tasks every month. Once signed in, you will see the dashboard where you can start creating your workflow.
In Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button located in the top right corner of your dashboard. This will open a dialog box where you can name your workflow. using Pabbly Connect
- Name your workflow: ‘Automatically Post from Facebook Page to LinkedIn’.
- Select a folder for organization, such as ‘Facebook Page Automations’.
After filling in these details, click on the ‘Create’ button. This sets up the framework for your automation, which consists of a trigger and an action. The trigger will be your Facebook page post, and the action will be the LinkedIn post.
3. Setting Up the Facebook Page Trigger
To set up the trigger in Pabbly Connect, select ‘Facebook Pages’ as the trigger application. Choose the trigger event as ‘New Post’. This means that whenever a new post is published on your Facebook page, it will trigger the automation.
Next, click on the ‘Connect’ button. A new window will prompt you to add a new connection. Ensure you are logged into your Facebook account in another tab to facilitate this connection. Authorize Pabbly Connect to access your Facebook Pages.
- Select your Facebook page, for example, ‘Digital Dynamics’.
- Click on the ‘Save and Send Test Request’ button to check the connection.
Once you create a new post on your Facebook page, Pabbly Connect will capture the response, confirming that the trigger is set up correctly.
4. Setting Up the LinkedIn Action
After configuring the trigger, the next step in Pabbly Connect is to set up the action application. Select ‘LinkedIn’ as your action application and choose the action event as ‘Share an Article or URL’. This will allow the captured Facebook post to be shared on LinkedIn.
Click on the ‘Connect’ button, and authorize Pabbly Connect to access your LinkedIn account. After authorization, select the author who will be sharing the content. Next, you will need to map the content from the Facebook post to your LinkedIn post.
Map the content field to the data captured from the Facebook post. Map the URL of the image to ensure it appears in your LinkedIn post. Set the visibility of the post to ‘Pabbly’.
After mapping all necessary fields, click the ‘Save and Send Test Request’ button. This will test the LinkedIn action to ensure everything is working correctly.
5. Verifying the LinkedIn Post
Once you have set up the action in Pabbly Connect, it is time to verify if the automation works. Go to your LinkedIn profile and refresh the page. You should see the new post that was automatically created from your Facebook page post.
If everything is set up correctly, the content from your Facebook post, including any images, should now appear on your LinkedIn profile. This confirms that the integration between Facebook and LinkedIn has been successfully established using Pabbly Connect.
This automation not only saves you time but also helps in reaching a wider audience across different platforms without manual effort. You can now focus on creating more engaging content for your audience.
Using Pabbly Connect, you can seamlessly automate posting from your Facebook page to LinkedIn. This integration saves time and enhances your social media presence, allowing you to engage with a broader audience effortlessly.
