Learn how to automatically create Instagram posts every day with Pabbly Connect. This step-by-step guide covers the entire integration process. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
1. Accessing Pabbly Connect for Instagram Automation
To start automating your Instagram posts, access Pabbly Connect by visiting its official website. Once there, you will find options to either sign in or sign up for a free account.
If you’re a new user, you can sign up for free and receive 100 tasks every month. After signing in, navigate to the Pabbly Connect dashboard to begin creating your automation workflow.
To create a new workflow in Pabbly Connect, click on the ‘Create Workflow’ button located at the top right corner of the dashboard. You will be prompted to name your workflow.
For this automation, name your workflow ‘Automatically Create Instagram Post Every Day’ and select the appropriate folder to save it. After naming, click on the ‘Create’ button to proceed.
  • Name your workflow.
  • Select the appropriate folder.
  • Click on the ‘Create’ button.
Now, you need to set up the trigger for your workflow. In Pabbly Connect, triggers initiate the workflow, so select ‘Scheduled by Pabbly’ as your trigger application.
3. Setting Up the Trigger for Daily Posts
In this step, you will configure the trigger to run every day at a specific time. Choose the ‘Schedule Workflow’ event and click on the ‘Create’ button. Set the frequency to ‘Every Day’ and select the desired time, such as 12:00 PM.
After setting the time, click on the ‘Save’ button. This configuration ensures your Instagram posts are created daily at the specified time using Pabbly Connect.
  • Choose ‘Scheduled by Pabbly’ as the trigger application.
  • Set the trigger event to ‘Schedule Workflow’.
  • Select ‘Every Day’ and the time for posting.
With the trigger set, your workflow is now scheduled to create Instagram posts daily at 12:00 PM, utilizing the capabilities of Pabbly Connect.
4. Generating Unique Captions and Images
Next, you will generate unique captions for your Instagram posts using OpenAI. Add an action step and select OpenAI as your action application. Choose the ‘Chat GPT’ event and connect it to Pabbly Connect by entering your API token.
For the prompt, write a detailed request like, ‘Generate a 100% unique Instagram caption related to skincare, beauty routine, and product highlights.’ This will guide OpenAI to create engaging captions for your posts.
Select OpenAI and the ‘Chat GPT’ event. Enter your API token to connect. Provide a detailed prompt for caption generation.
Once the caption is generated, you can use it in your Instagram post, ensuring daily fresh content with the help of Pabbly Connect.
5. Publishing the Instagram Posts Automatically
After generating the caption, the next step is to publish the Instagram post. Add another action step, choose Instagram for Business, and set the action event to ‘Publish Post.’ Connect your Instagram account to Pabbly Connect to facilitate this integration.
Map the generated caption and the image URL to the respective fields and click on the ‘Save and Send Test Request’ button. This will create the post on your Instagram profile automatically.
Select Instagram for Business as the action application. Set the action event to ‘Publish Post.’ Map the caption and image URL before saving.
With this setup, every day at the scheduled time, Pabbly Connect will automatically generate and publish a new Instagram post, streamlining your content creation process.
Using Pabbly Connect, you can effortlessly automate the process of creating and posting unique Instagram content daily. This integration not only saves time but also ensures consistent engagement on your profile. Start automating your Instagram posts today!
