Learn how to automatically add MailerLite subscribers when an order is placed in Digistore24 using Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To start the integration process, first log in to your Pabbly Connect account. If you don’t have an account, you can create one for free. Once logged in, navigate to the dashboard where you can set up new workflows.
Click on the ‘Create Workflow’ button to initiate the process. Name your workflow something relevant like ‘MailerLite Subscribers from Digistore24 Orders’. This will help you identify the workflow later. Pabbly Connect will now guide you through the steps to connect your applications seamlessly.
2. Connecting Digistore24 to Pabbly Connect
In this step, you will connect Digistore24 to Pabbly Connect. Choose ‘Digistore24’ as your trigger application. You will need to select the trigger event, which is typically ‘New Order Placed’. This event will trigger the workflow whenever a new order is made.
- Select the trigger event as ‘New Order Placed’.
- Connect your Digistore24 account by providing the required API key.
- Test the connection to ensure it is working properly.
Once connected, you can proceed to set up the necessary fields that need to be captured from the order details. Pabbly Connect will allow you to map these fields to MailerLite later.
3. Adding MailerLite Subscribers Automatically
Next, you will configure the action step to add subscribers to MailerLite using Pabbly Connect. Select MailerLite as your action application. Choose the action event as ‘Add Subscriber’. This will allow you to add a new subscriber automatically whenever an order is placed in Digistore24.
- Map the fields from Digistore24 such as customer name, email, and any other relevant information.
- Select the MailerLite group where the subscriber will be added.
- Test the action to ensure the subscriber is added correctly.
This step ensures that every new order placed will result in an automatic addition of the customer to your MailerLite subscriber list, enhancing your email marketing efforts.
4. Testing and Activating Your Workflow
After mapping all necessary fields and ensuring that the connections are correct, it is crucial to test your workflow in Pabbly Connect. Perform a test by placing a dummy order in Digistore24 and checking if the subscriber is added to MailerLite as expected.
Once the test is successful, you can activate your workflow. This means that every time a new order is placed, the integration will work automatically without any manual intervention. Make sure to monitor the workflow initially to ensure everything operates smoothly.
5. Conclusion
Using Pabbly Connect to integrate Digistore24 with MailerLite allows for efficient subscriber management. By following the steps outlined, you can automate the process of adding subscribers, ensuring that your email marketing is always up to date with new customers. This seamless integration enhances your business efficiency and customer engagement.
For more detailed guides and tutorials on using Pabbly Connect and other applications, stay tuned to our channel and subscribe for updates!
