Learn to automate employee onboarding emails using Pabbly Connect, Google Sheets, and Gmail with this detailed step-by-step tutorial. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To automate employee onboarding emails using Pabbly Connect, you first need to access the platform. Start by visiting Pabbly.com/connect in your browser. This will take you to the Pabbly Connect homepage.
On the homepage, you will see two options: Sign In and Sign Up Free. If you are a new user, click on Sign Up Free to create an account. Existing users can simply sign in. Pabbly Connect offers a free plan that allows you to explore its features with 100 tasks every month.
Once signed in, navigate to your dashboard and click on the ‘Create Workflow’ button. This will prompt you to name your workflow. Enter a name that reflects its purpose, such as ‘Automate Employee Onboarding Emails with AI’. using Pabbly Connect
  • Select the Beta version for a modern interface.
  • Choose a folder for your workflow, such as ‘Automations’.
After naming your workflow, click on the ‘Create’ button to proceed. This will take you to the workflow builder where you can set up the trigger and action steps.
3. Setting Up the Trigger with Google Sheets
In this step, we will set up the trigger for our automation using Google Sheets. Select ‘Google Sheets’ as your trigger application and choose the event as ‘New Updated Spreadsheet Row’. This means that every time a new employee detail is added to the Google Sheet, it will trigger the workflow.
Next, you will need to connect your Google Sheets account with Pabbly Connect. After connecting, select the specific spreadsheet that contains your employee onboarding details. Make sure that the last column in your Google Sheet is set as the trigger column, which will send the data to Pabbly Connect.
4. Generating Email Content Using AI
After setting up the trigger, the next step is to generate the onboarding email content using an AI tool. For this, select ‘OpenAI’ as your action application and choose the event as ‘Create Completion’. This allows you to generate personalized email content based on the employee details captured from Google Sheets. using Pabbly Connect
  • Input your API key from OpenAI to connect it with Pabbly Connect.
  • Map the employee details from the previous step to the prompts in OpenAI.
  • Set the model to GPT-3 or GPT-4 based on your preference.
This integration will allow Pabbly Connect to generate a personalized onboarding email for each new employee added to your Google Sheet automatically.
5. Sending the Email via Gmail
The final step in the automation process is to send the generated email to the new employee using Gmail. For this, select ‘Gmail’ as the action application and choose the event as ‘Send Email’. Connect your Gmail account with Pabbly Connect to facilitate this.
Fill in the necessary fields, such as the recipient’s email address, subject line, and the body of the email, which is generated by the AI tool. Once you have configured all the settings, click on the ‘Save and Send Request’ button to finalize the email sending process.
In this tutorial, we demonstrated how to automate employee onboarding emails using Pabbly Connect, Google Sheets, and Gmail. By following these steps, you can streamline your onboarding process and ensure that every new employee receives a personalized email automatically. This integration not only saves time but also enhances the onboarding experience for new hires.
